08 CrewMax 4wd problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Wireman2003, Dec 9, 2019.
  1. Dec 9, 2019 at 8:49 PM
    Wireman2003
    Wireman2003 [OP] New Member
    Mark
    08 Tundra CrewMax
    I’m a new comer. When I put it in 4hi I can hear it go in and light flashes. After about 3 seconds I hear it disengage and light flashes faster. And I never hear the front diff do nothing. I have took both hi and lo actuators apart and they look fine because looks like they have been took off before. And the front diff looks good to. I tested all motors and they operate. I would appreciate everyone’s help. Thanks
  2. Dec 9, 2019 at 10:26 PM
    dru741
    dru741 New Member
    2014 Silver Tundra SR5 TRD CM
    I have a similar problem with my 14. It will sound like it engages but just flashes until I go back to 2wd. However when I go to 4wd and restart engine, it will fully engage and work as it should until I go back to 2wd. Currently working on my issue, waiting on t case fluid to come in.
  3. Dec 11, 2019 at 5:30 AM
    Wireman2003
    Mark
    08 Tundra CrewMax
    Could it be a relay, fuse, or module if so where do I look to find it. I’m confused. Has anyone had a wiring diagram on the 4wd system. And a diagram on the way the gears are supposed to be on both the hi and lo actuators. And is the actuator shafts need to be pushed all the way in toward the front of truck. Or can someone point me in the right direction. Thanks
  4. Dec 11, 2019 at 6:38 AM
    timsp8
    NY
    kparrow likes this.
  5. Dec 11, 2019 at 7:09 AM
    Wireman2003
    Mark
    08 Tundra CrewMax
    Thanks that’s a great video and looks like my shafts should be in the right position cause they should pull out away from transfer case.
  6. Dec 11, 2019 at 7:33 AM
    Wireman2003
    Mark
    08 Tundra CrewMax
    Before I put the hi actuator back together I plugged it in to see if it operated and it did but light still flashed and it didn’t operate the the other way. It’s like it’s not communicating with the front diff.
  7. Dec 13, 2019 at 2:57 PM
    Wireman2003
    Mark
    08 Tundra CrewMax
    Well I took the hi actuator apart again to see if I could move the rod that goes into the TC and it was hard to move and I noticed the rod was bent or the whole actuator case was so I loosened the case and put washers behind bottom left and know it will operate fully. So I put it back together and it operated but the front diff didn’t and it want disengage and the VSC off light is on. NOW WHATA89A95A9-E3B2-4F20-9D16-FCE3E17EFA80.jpgA89A95A9-E3B2-4F20-9D16-FCE3E17EFA80.jpg
