08 5.7 6 speed automatic transmission. No reverse
Discussion in 'New Member Introductions' started by Olmule, Nov 21, 2021.
  1. Nov 21, 2021 at 1:24 PM
    Olmule
    Olmule [OP] New Member
    Ok so here I go again. 08 5.7 6 speed 270000 miles. Just bought it knowing that it won't go into reverse. So it has all it's forward gears but no reverse and no neutral or 4 low. Any help would be great thanks
  2. Nov 21, 2021 at 1:30 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Welcome..... from the high desert.. A.V.
    First get it scanned for codes... Take it to a shop or autozone or simular store and have them run a full diagnostic that will grab all codes... not just the basic ones.... I splurged on a blue driver but there are better ones out there...
    People will take jabs in the dark and have you chase your tail with no solution, my suggestion is start there.. but if you want a free jab.. replace the transmission...
  3. Nov 21, 2021 at 2:04 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    First post needs a hearty welcome... Hearty welcome and good luck.. Any pics?
  4. Nov 21, 2021 at 2:40 PM
    Olmule
    Did that already no codes are showing or even in history. And it makes a humming sound in trans pan when the brake is applied.
  5. Nov 21, 2021 at 3:39 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  6. Nov 23, 2021 at 9:12 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    time to visit a trusted transmission shop
  7. Jun 22, 2024 at 4:08 PM
    Cesarion23
    Cesarion23 New Member
    2013 black tundra 2wd
    Did you fix the issue?
