07 Tundra Transmission
Discussion in '2nd Gen Tundras (2007-2013)' started by tundra2007, Apr 19, 2019.
  1. Apr 19, 2019 at 7:15 PM
    tundra2007
    tundra2007 [OP] New Member
    Dave
    2007 Toyota Tundra, 5.7 engine, SR5
    Dual exhaust, air bags
    I'm new to this. I have been researching how to change fluid in my 07 tundra. I have heard about flushing, also draining and changing filter and refilling with WS. There were a couple other methods suggested. Not sure what to do with my 07 SR5 -5.7. It's got 205K wonderful miles on it and I never touched the trans except to use it. I guess if it ain't broke, don't fix might apply here but she's getting old. Can anybody give me some advice here?
  2. Apr 19, 2019 at 8:14 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Many do a drain and refill, gets about 25% new fluid into the mix. 90k mile recommended in manual. Kind of tricky DIY, many get done at shop.
    A flush can be done, replacing all the fluid, not DIY unless your a mechanic. Some think this unwise, could stir up trash otherwise left alone, some claim no issues.
    With that many miles, a pan drop and filter change probably in order as well as a drain and fill at minimum.
    There are also synthetics that are compatible with WS, which also should be better than WS.
    Shop prices seem to vary quit a bit, call around for best pricing.
    There are some YouTube videos as well.
    Good luck
