07 Tundra Not Starting. Dash gauges not activating when I turn key.
Discussion in '2nd Gen Tundras (2007-2013)' started by Hummelv34, Jan 18, 2025.
  1. Jan 18, 2025 at 8:58 AM
    Hummelv34
    Hummelv34 [OP] New Member
    Vincent
    2007 Tundra 5.7L V8 2WD
    I am having a problem with my Toyota Tundra 2007 5.7L. It is not starting, there is a single click and that’s it. The battery is good. This all happened in one day, my truck was starting up great in the morning and then I go to start it up again and then boom this issue occurs. On top of that all of my dash gauges do not activate when I turn the key. I checked all of my ignition fuses, I also replaced the starter relay. I have feeling this is a wiring issue I’m just not sure the best way to diagnose it. Any suggestions?
  2. Jan 18, 2025 at 9:03 AM
    BGBTundra
    BGBTundra New Member
    Sacramento, Ca.
    '08 CM Limited 4x4
    This happen to me about a month ago...the one click and no start. It ended up being my battery terminals. The wires were dirty but the connections looked ok, didn't think it would be it but upon reading old threads on here and talking with my brother (who also owns a 2nd gen Tundra), I went ahead and started at the battery connections. I replaced one of the terminals and used a wire brush to clean off the rest of the connections. Started right up after that.
    KNABORES likes this.
  3. Jan 18, 2025 at 9:08 AM
    Hummelv34
    Vincent
    Okay thank you for the response I will try this next. I’ll keep you updated.
  4. Jan 18, 2025 at 10:36 AM
    Hummelv34
    Vincent
    Did your dash gauges work when you were having this issue with your tundra?
  5. Jan 19, 2025 at 12:18 PM
    BGBTundra
    Sacramento, Ca.
    '08 CM Limited 4x4
    It was sporadic, at first all my gauges worked. After trying a few more times, it stopped lighting up after each attempt. And after a random attempt and I got the truck started, my 4LO and traction control lights were blinking, these light never blinked before. All of these problems went after I replaced one battery terminal and wire brushed all of the other battery connections til it was shiny.
  6. Jan 19, 2025 at 12:22 PM
    Ground cables, battery terminals and battery health would be on my hit list for these problems
  7. Jan 19, 2025 at 3:35 PM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Ditto bro!
