07 tundra no power
Discussion in '2nd Gen Tundras (2007-2013)' started by Kirkb73, May 10, 2021.
  1. May 10, 2021 at 9:12 PM
    Kirkb73
    Kirkb73 [OP] New Member
    William
    2007 tundra sr5
    My truck started a few days ago where if you give it more than 25% gas pedal the rpms will go to around 3000 but truck feels like it's going nowhere. Showing no codes but I can unhook battery for a few minutes and it will go back to normal. Usually have to do this once a day but after I unhook battery it is fine the rest of the day. Any ideas?
  2. May 10, 2021 at 11:01 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Sounds like limp mode, like the dreaded SAIP failure... maybe you cleared the code when you disconnected the battery...
  3. May 11, 2021 at 1:43 PM
    Kirkb73
    William
    2007 tundra sr5
    I checked it before I disconnected the battery. Whatever it is gets reset when battery gets disconnected. Just no clue on what it could be to not be throwing a code
  4. Aug 17, 2022 at 7:38 AM
    CuzItwrks
    CuzItwrks New Member
    Did you figure out what was wrong, my 2007 is doing the same thing.
  5. Aug 17, 2022 at 10:35 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Sounds fuel related
  6. Aug 22, 2022 at 3:57 PM
    Matts7252
    Matts7252 New Member
    Matthew
    2008 black tundra
    8 in suspension lift 2 in body lift 37x14x18 mud tires aftermarket touch screen car audio system 2 10” subs
    My 2008 is in limp mode. All codes have been cleared but shows nothing about any errors or codes to suggest it’s in limp mode. It will not got over 25% throttle and I keep throwing money into it but nothing seems to get it out of limp mode. It does have a bullydog chip system don’t know if that’s relevant but please help anyone!!
