07 Tundra limited 4d 4x4 tire cupping???
Discussion in '2nd Gen Tundras (2007-2013)' started by taylor36, Nov 13, 2018.
  1. Nov 13, 2018 at 7:17 PM
    taylor36
    taylor36 [OP] New Member
    Taylor
    07 White Tundra 4D Limited 5.7L 4WD
    Bilstein 5100 on all four corners fronts on highest clip position
    Hey guys, I am new here so.. Whats up. I searched and found some threads but didn't really describe my particular situation, so here goes.
    I bought a new set of Nitto Ridge Grapplers, they are 275/65-18's. At the same time I also had a rough country leveling kit installed, with diff spacer. At the first tire rotation (5.2K) noticed some cupping and was told probably alignment. So I took it to Les Schwab and had it aligned less than 15 miles later. Drove it for another 5K and in between kept checking and the cupping never stopped and the truck didn't drive any better after alignment so I kinda thought maybe that wasn't it. I had them warranty the alignment anyways for good measure. This cycle repeated a number of times where I go get em rotated and still cupping.
    So I took it to another shop and had them try to diag what the issue was. I was told it needs new shocks and they recommend Bilstein 5100 adjustable ride height kit. Ok cool go ahead and slap that on and remove rough country leveling kit. so we did that and keep in mind these tires have been repeatedly rotated and constantly being checked and run at 35 psi. by the way they are load range E (10 ply). In the end guys, I just wanna know why my flipping tires are cupping. Wheel bearings are good, ball joints are good, tie rods are good... so im kinda at a loss!?!?
    Anyone have any ideas??? Any help would be greatly appreciated. I am going to try to figure out how to upload photos and will update this hopefully within the hour.
    Thanks guys!
    Mountun Goat likes this.
  2. Nov 13, 2018 at 7:33 PM
    Welcome from Ohio!
    Are they cupping both on the front and back or just the front?
  3. Nov 13, 2018 at 7:37 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Pics would be good, but can you describe how the tires are cupping? Along outer edges, inner edges, across entire tread surface?
    If you have an alignment print-out, post a pic of that too.
    And welcome!
  4. Nov 13, 2018 at 8:00 PM
    taylor36
    Taylor
    Just the two front, no cupping on the back, those wear completely square. Trying to figure out the pics
  5. Nov 13, 2018 at 8:33 PM
    jpmull78
    jpmull78 New Member
    2010 TRD Crewmax LRO 3/1 Nitto 325/65 R18 - 18x9 35offset Ultra Wheels
    I had a 2009 and now a 2010 both with same set up. 3/1 LowRange Offroad kit. You have to excessively rotate tires and do a hell of a burnout...LOL Next week I am getting new tires, new shocks, and Toytec Eibach 3" lift coilovers and ADJUSTABLE CONTROL ARMS. As expensive as they are, they will protect my tire investment. I've had multiple shops over the years tell me they can only get the alignment to go so far. I've had the same issues for years.
  6. Nov 13, 2018 at 8:35 PM
    taylor36
    Taylor
    so where is the issue? in the control arms and how much we talking for adjustable ones
  7. Nov 13, 2018 at 8:40 PM
    taylor36
    Taylor
    also I no longer have a leveling kit installed. there is no spacer now I just run the bilstein on the highest clip position but was told to leave diff spacer kit installed
  8. Nov 13, 2018 at 8:51 PM
    jpmull78
    jpmull78 New Member
    The stock control arms are have no adjustment. The aftermarket ones that are adjustable allow for Adjustment range: Camber +/- 2.00 degree
    Caster 0.0 degree to +4.00 degree. Prices that I see range from 400 - 1200 depending on brand and how fancy they are. The ones on LowRange are SPC for about $600, but I just found them on Amazon for $480. I like to work on it myself but my local trusted offroad shop is going to install the shocks and coilovers for $200 and I'm hoping he will just throw the control arms in there as well. I decided on the control arms today after I had made the deal on the coil over installation.
  9. Nov 13, 2018 at 8:52 PM
    jpmull78
    jpmull78 New Member
  10. Nov 13, 2018 at 8:54 PM
    jpmull78
    jpmull78 New Member
    And yes, I am pulling the On Top of the Coil Spacer from LowRange off and then put the Toytec 3" coilovers in.
  11. Nov 13, 2018 at 8:58 PM
    taylor36
    Taylor
    #1 I wonder if this is the issue, I have alignment printout and it doesn't look bad to me except the toe. I wish I could post a photo of it lol.
  12. Nov 13, 2018 at 9:10 PM
    jpmull78
    jpmull78 New Member
  13. Nov 13, 2018 at 9:10 PM
    jpmull78
    jpmull78 New Member
    What's your camber at?
  14. Nov 13, 2018 at 9:17 PM
    taylor36
    Taylor
  15. Nov 13, 2018 at 9:18 PM
    taylor36
    Taylor
  16. Nov 13, 2018 at 9:18 PM
    taylor36
    Taylor
  17. Nov 13, 2018 at 9:19 PM
    taylor36
    Taylor
  18. Nov 13, 2018 at 9:19 PM
    taylor36
    Taylor
  19. Nov 13, 2018 at 9:20 PM
    taylor36
    Taylor
    I figured it out... see im really not that dumb
    landphil and jpmull78 like this.
  20. Nov 13, 2018 at 9:25 PM
    jpmull78
    jpmull78 New Member
    Cool, my tires look the same.
  21. Nov 13, 2018 at 9:28 PM
    jpmull78
    jpmull78 New Member
    I just purchased the SPC control arms on Amazon. $520 drive out. Looking really forward to the change after almost 10 years of the same setup and nursing expensive tires. Hoping the ride is better with the coil overs as well.
  22. Nov 13, 2018 at 9:28 PM
    taylor36
    Taylor
    lol NOT COOL I fetching hate it. It drives me nuts to the point its all I think about when driving lol
  23. Nov 13, 2018 at 9:29 PM
    taylor36
    Taylor
    what shocks are currently on your truck?
  24. Nov 13, 2018 at 9:32 PM
    jpmull78
    jpmull78 New Member
    I agree, that's why I am done with this crap. I have spent so much time at Discount Tire waiting on rotation and balance, and then it still not be smooth. I've also learned that Tundra brake rotors are crap and warp easily. So if you are braking and have alot of shutter and shake, get some upgraded slotted rotors. I just installed Power Stop Evolution Brakes and Rotors. Smoooooth as butter.
  25. Nov 16, 2018 at 8:00 PM
    taylor36
    Taylor
    Well... im not sure why some tundras do it and some don't. Someone out there has to know what causes this lol.
  26. Nov 23, 2018 at 8:41 PM
    taylor36
    Taylor
    I gave it a week and I think its getting slightly better. either that or my tires are low enough that it doesn't look as bad anymore lol.
