07 Tundra Changed my battery and Anti theft alarm keeps going off
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra071024, Mar 27, 2023.
  1. Mar 27, 2023 at 9:29 PM
    Tundra071024
    Tundra071024 [OP] New Member
    Recently changed my battery and when I went to connect the negative terminal, the security alarm started blaring and the truck won’t crank. Anyone know how to disable or reset this? Thanks.
  2. Mar 27, 2023 at 9:37 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    key in the ignition and turn it to on 2 times quickly, don't start the truck. Should disable the alarm system. If you do it correctly then the red light on the dash will blink 2 times per blink quickly. To turn it back on do the same thing, the blinking shoukd stop. When reconnect the battery I hold the key fob because the alarm goes off every time. I would also check the negative terminal and ensure it's on tight.
  3. Mar 28, 2023 at 6:11 PM
    Tundra071024
    I tried that today but no luck. I’ve tried about everything I could find on forums and no luck
  4. Mar 28, 2023 at 7:34 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Did you try the key in the driver side door?
    Lock and unlock the driver door with the key back and forth several times.
