07 Misfire on cylinder 8
Discussion in '2nd Gen Tundras (2007-2013)' started by Damien311, Dec 3, 2018.
  1. Dec 3, 2018 at 9:31 AM
    Damien311
    Damien311 [OP] New Member
    Diagnostics show I have a misfire on cylinder 8. I replaced the spark plugs and everything was running perfect. Next morning check engine light is blinking along with VSC. I got to where I was going, went into the store, came back out and my truck ran perfect once again. This morning, same issue, check engine and VSC is blinking. What should my next move be?
  2. Dec 3, 2018 at 10:06 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Swap coils between cylinders and see if it follows the coil
    15whtrd and landphil like this.
  3. Dec 3, 2018 at 12:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What the burrito said. If the issue stays with the cylinder, instead of moving with the coil pack, then you know it’s not the coil pack, or vice-versa.
    I do have to ask though, are you loosing any coolant? Any sweet coolant smell to the exhaust when it missfires?
  4. Dec 3, 2018 at 1:06 PM
    Damien311
    14burrito Thanks, I already pulled the trigger on 8 new coil packs....
    landphil, coolant is good and the exhaust does smell a little rich but not sweet.
  5. Dec 3, 2018 at 1:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That’s good news. A cylinder specific missfire usually only on cold start-up after sitting can be a sign of coolant slowly leaking into the cylinder from a head gasket failure etc. A coil pack or even 8 would be far easier on the wallet, and a very real possibility.
    Do keep us updated.
  6. Dec 3, 2018 at 2:23 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I had the same issue with my 2012, it happened under hard acceleration. The truck went into limb mode, the vsc was flashing, check engine the whole nine. Turns out it was a it was a bad coil. Swapped out the bad one, changed sparks. All was good until a sold my truck. It happened at 50k sold truck with around 120k
  7. Dec 3, 2018 at 2:42 PM
    Damien311
    NjPro, thank you for the input and helping me stay positive on this. She's been good to me for 8 years, 230k miles and I have only had to deal with the starter. I will update when I receive the coils on Wednesday.
    NjPro and landphil like this.
  8. Dec 3, 2018 at 3:39 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    No worries, we all know the feeling. For sure keep us posted. Good luck.
  9. Dec 14, 2018 at 5:42 PM
    Damien311
    11 Days later.....
    Replaced the spark plugs, ignition coils....same code, misfire on cylinder 8. Took it to a mechanic to see if they could diagnose further, they check compression on the cylinder...it was good $85. Same problem popped up 2 days later....told them I was low on gas when it happened, put gas in, started it up and no issue for the day. They thought it might be a hose to the fuel pump issue, hairline crack in the hose. Took it to another mechanic, today....they had it all day and have pin pointed it to the fuel injector or the computer. They left a device on my injector for me....if the issue pops up again, when lite the computer is sending the signal to the injector and it is the injector, if the light goes out, it is the computer.
    Fingers crossed that it is the injector!
    The mechanic had an emergency to handle and I will be seeing him on Monday...would not take any money from me until it is fixed.
    I will update next week....hope this helps at least one person.
    NjPro and 14burrito like this.
  10. Dec 14, 2018 at 5:51 PM
    15whtrd
    15whtrd Mr. Blonde
    Could a fuel pump cause this?
  11. Dec 14, 2018 at 6:11 PM
    Damien311
    15whtrd, No...I forgot to mention that part.
    I took it to the 2nd mechanic because he was going to charge me half to do it....
    Within an hour, he had ruled out the fuel pump issue.
    Sunnier and 15whtrd like this.
  12. Dec 14, 2018 at 6:20 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    Thanks for the update. Also it is really cool the mechanic is not trying to fleece you. Good luck.
  13. Dec 14, 2018 at 6:41 PM
    Damien311
    NjPro....he is an awesome mechanic, as of right now.
    It is sad though, just found him but his ranch is almost complete in Mexico and will be leaving soon.....Levy is his name.
    15whtrd and NjPro like this.
  14. Dec 14, 2018 at 6:44 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    [QUOTE="Damien311,
    It is sad though, just found him but his ranch is almost complete in Mexico and will be leaving soon.....Levy is his name.[/QUOTE]
    This sounds like the beginning of western book or movie.
  15. Dec 14, 2018 at 6:47 PM
    Damien311
    NjPro....I'm thinking you are on to something.
    NjPro likes this.
  16. Dec 15, 2018 at 11:38 AM
    Damien311
    Update....
    Drove it this morning, half way to my destination and the check engine light came on. Got to where I was going and looked at the sensor the mechanic put in...light was off. Meaning it is the ECU not sending proper signal to the injector. No clue on cost, may look for a scrapped Tundra to pull it off of.
    Will update on Monday.
    NjPro likes this.
  17. Dec 15, 2018 at 11:46 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    I think a used ecu from a wreck will be the best way to go.
  18. Dec 15, 2018 at 11:54 AM
    Damien311
    NjPro....We were thinking the same but, Ebay has them for around $250...I will see what advice of the mechanic has.
    Being an electrician myself, I do not want to pretend to know the best route.
    NjPro likes this.
  19. Dec 15, 2018 at 12:11 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    Agreed, I would be a lost sailer at sea trying to swap out the ecu.
  20. Dec 20, 2018 at 5:51 PM
    Damien311
    Update....
    2nd day that I have had it back and it seems as though the problem is fixed.
    He determined it was the ECM, ordered it, installed, and programmed.....a bad injector shows up.
    He states that the bad injector caused the original ECU to fail.
    Again, I am an electrician trying to follow along and understand.....
    I want to believe him but I am about 80%/20%.
    Here is the bill I was sent: (keep in mind, he spent 4 days trying to pin point the issue)
    1) ECM - $220.00
    2) Re Programming $140.00
    3) Injector $155.00
    4) Oil Change $75.00
    5) Labor $300.00
    Seems Pretty Legit to me.....Comments?
    Sunnier and NjPro like this.
  21. Dec 20, 2018 at 5:55 PM
    NjPro
    NjPro New Member
    Tom
    Nj
    Seems legit, glad your up and running. Peace of mind will come the more that time passes with out any lights on the dash.
  22. Dec 20, 2018 at 6:05 PM
    15whtrd
    15whtrd Mr. Blonde
    What do they have to program onto the new ECM? I also don’t understand how a bad injector can ruin an ECM.
    NjPro likes this.
  23. Dec 20, 2018 at 6:15 PM
    Damien311
    NjPro...You are very correct, I had a dream this morning that the check engine light came on....I hope this will pass.
    15whtrd...I can not answer that, I just hope he is being honest. Truck is running great, who am I to question?
    NjPro and 15whtrd like this.
  24. Dec 20, 2018 at 6:41 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    You need to tie the VIN to the ECM through the "cloud".
    IMO he only charged you for the injector because he couldn't return a used part. Thats unfortunately part of the "part swap" diagnosing game.
    Sunnier, NjPro and 15whtrd[QUOTED] like this.
  25. Dec 25, 2018 at 7:28 AM
    FXFormat
    FXFormat New Member
    That's a rare case for the ECM to go bad resulting in a misfire. I'm a mechanic and when we get a misfiring car 90% of the time it's a bad coil, 7% of the time it's a bad spark plug, 2.999% of the time it's the injector. Rarely, actually i've never seen one at my shop with a bad ECM causing a misfire. Glad you are up and running, the bill that you're charged with is not bad at all.
  26. Jun 1, 2019 at 8:53 AM
    axbello502
    axbello502 New Member
    Axel
    2006 Toyota Tundra
    2.5" lift/leveling kit. Cold air intake, Flowmaster super 44 muffler.
    I agree with FXFormat's numbers, but in my case, I have seen ECM's going bad due to a failed injector. Most common injector failure is excessive resistance, caused by undergoing multiple heat/cold cycles. But once in a while you see an injector with little or no resistance, most commonly known as grounded or shorted, this would typically blow a fuse, but in some instances the path to ground isn't strong enough to blow a fuse, but too consistent for the ECM to keep up and ends up burning the Diode the controls the circuit for that specific injector. Now on the other hand, when that's the case, usually Technician will find the failed injector first, since is easy to test injectors and figure which one is "shorted". After replacing it, and if still having a missfire you'll know the ECM has also been affected and needs to be replaced (or fixed if you know what you're doing), so with that being said, if the tech tested injectors while hot and cold and found no issues, chances are a grounded wire on that injector circuit was the culprit and could have fried the computer, and if not addressed properly, it will eventually ruin the new one too.
