07-13 Toyota Tundra Parasitic draw ECU B-1
Discussion in '2nd Gen Tundras (2007-2013)' started by Steve_82, Oct 29, 2023.
  1. Oct 29, 2023 at 6:46 AM
    Steve_82
    Steve_82 [OP] New Member
    2011 Toyota Tundra SR5 Crew Cab
    Hello I bought my truck in February and everything ran great, until one day my horn quit working, I researched it to find out the clock spring needed replaced, then the battery died, replaced it, then the starter took a crap, replaced it, next the alternator, replaced it and the serpentine belt, and replace the battery again, 1 week later battery dead again, I later noticed that the clock on my dash was always staying on even after the key was pulled from the ignition!!! Yesterday I took the subwoofers and amp out of the truck to hopefully get this thing figured out, however the clock is still on!!!! The only way I can get it to shut off is when I pull the ECU B1 fuse under the hood, however now the keyless fob doesn’t work and the a/c doesn’t work amongst a couple other features, what is going on with this thing, by replacing the clock spring will that help????
  2. Oct 29, 2023 at 6:47 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Have you tried replacing the clock spring?
  3. Oct 29, 2023 at 7:01 AM
    Steve_82
    Thank you for your reply! Not yet, do you think it would that cause a parasitic draw?
  4. Oct 29, 2023 at 7:23 AM
    Shanet421
    San Diego,CA
    I am not 100% certain in that. I have herd of them causing all types of issues and for $20-$30 it’s cheap enough to try
  5. Oct 29, 2023 at 8:09 AM
