06 tundra wont start after engine pull/bypass kit
Discussion in '1st Gen Tundras (2000-2006)' started by Cthur, May 1, 2023.
  1. May 1, 2023 at 8:26 PM
    Cthur
    Cthur [OP] New Member
    Ive got a 2006 tundra double cab 2wd 4.7L.
    Ive had it for about 12,000 miles /2 years now no issues.
    I have noticed a hot anti freeze smell the past 3 months. But no signs of over heating.
    Today i cranked it up and it had a CEL for p0412. After driving it around 16 miles at lunch it started steaming and boiled the fluid out of the over flow onto ground. Gauge was at half way mark when this happened.
    I got it towed to the house and put 1 gallon of water in it and it was full.
    Cranked it up let it idle for 15 mins and it stayed dead center of gauge.
    So i reved it up and it went to 3/4 gauge and i just cut it off.
    So i am in process of replacing the air pump under the intake. Its a very dirty motor. Previous owners just didnt take good care.
    Has anyone had this code cause over heating before or am i looking at separate issues?
  2. May 1, 2023 at 8:39 PM
    I'm thinking separate issues. SAIP only runs for ~1min at startup and its purpose is to
    However, if you have air in your coolant system, it can cause overheating - you need to ensure you're burping the system properly when adding coolant. Likewise, if you recently installed t-stat, the jiggle valve needs to be clocked between 11 and 1 during install.
    What work has been done to the vehicle most recently?
    What color coolant is in it? (Hopefully red)
    That was distilled water you put in it, right?
    You confirmed the fan is running, right?
    What maintenance do you know was done to the truck prior? Timing belt, water pump and tensioners? Anything else?
    Coolant smell can come from any number of things. But not knowing the mileage or history of the radiator, water pump, etc. it's hard to say what it would be.
    G_unit3000 and Aerindel like this.
  3. May 1, 2023 at 9:23 PM
    Aerindel
    Aerindel New Member
    Montana
    First thing I would do is replace the radiator cap. The system should never overflow at normal temps unless either cap is failed, or there is a failed headgasket letting exhaust gases into the system and overfilling it. This usually also causes overheating so my money is on a bad cap at this point since you say it wasn't overheating when it happened.
    Temporarily moderately overheating after needing to add a large amounts of fluid is normal, it means there is still air in the system from whatever happened previously. This usually self resolves after a couple cycles of heating and cooling OR a full burping of the coolant system.
    shifty` likes this.
  4. May 1, 2023 at 9:30 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You beat me to it. If you're filling the overflow to the top and blowing it out the lid I'd say definitely radiator cap is a good start. I've had that fix that problem for me twice now on different vehicles.
  5. May 2, 2023 at 3:33 AM
    Cthur
    Water pump and timing was done 30k ago, no recent work done to truck.
    Red coolant
    Yes distilled water from a jug
    not sure how to check fan
    Will replace cap and air pump tonight and see what happens
  6. May 2, 2023 at 7:22 AM
    Checking fan: See Aerindel's comment below, I was confusing with electric fan.
    When filling fluid, are you keeping the heater engaged and on high to circulate fluid completely? Are you certain the system has been burped properly and isn't holding air?
    With no coolant system maintenance done in 30k miles, I'd assume you'd have noticed if the t-stat hadn't been set correctly. I agree with the guys, replacing the cap should be a priority. But I think taking time to properly burp your system is something you can do now, without buying anything, air in the system could also be the cause.
    Schcoman likes this.
  7. May 2, 2023 at 2:22 PM
    Cthur
    Well thats not how a mechanical fan clutch work on jeeps/bmws it will always spin even if its bad. So not sure that the "big ass fan" would just not spin... at all
    And the air in the system wasnt there for 30k so im trying to figure out what may of caused the original overheat?
    Not sure... ordered air pump and cap
    Will try to burp system once i get those installed. Suppose to be my forever truck so i gotta get this thing 100%
  8. May 2, 2023 at 3:26 PM
    Aerindel
    Aerindel New Member
    Montana
    WAS there an original overheat? You say that the temp gauge was normal when it boiled over...this is not an overheat, this is an over pressure, or normal pressure, and a failed cap.
    Yeah, this is correct.
    On a mechanical clutch fan....the check is that when cold, you should be able to turn it by hand, with some resistance.
    When hot, (as in, after you ran the engine long enough to heat everything up to operating temp and then shut it off) you should not be able to turn the fan, without turning over the engine.
    If there is no resistance when cold, only light resistance when hot, or its locked solid when cold, those are all failures of the fan clutch.
    NickB_01TRD likes this.
  9. Apr 5, 2024 at 4:30 PM
    Cthur
    Fixed that issue , radi cap had exploded into peices ibside of radiator and something jammed my thermostat , replaced both and it was good. Still throwing codes for secondaey air now.
  10. Apr 5, 2024 at 5:25 PM
    SAIP codes, all you can do is replace pump and valves, or bypass. The latter isn't a guarantee of no codes; but it's far cheaper. Knowing the chances of the pump failing again during your lifetime of ownership are almost nil, I'd opt for pump/valves bypass. But it's easy for me to say: Not my money.
  11. Apr 6, 2024 at 9:00 AM
    Cthur
    Well thats where im stuck now, i bought the hewitt bypass kit, all 4 bolts broke so I had to remove the engine to fix them. So i just got it all back together last night.
    Now when i go to crank my starter does not turn over at all. Almost seems like power is giing to everything but starter
    Note i did break the sensor on the top of thermostat, should have replacement for that today.
    I ended up buying a 11' 4runner for my daily but i want my truck back on the road ...
  12. Apr 6, 2024 at 11:35 AM
    If the coolant sensor the ECU uses isn't functioning, the engine will not crank. At least this has been reported by more than one person here.
    Aerindel likes this.
  13. Apr 6, 2024 at 1:20 PM
    Cthur
    Oh well i hope thats it , got new sensor today got it installed now just gotta get a heat gun to splice in new connector.
  14. Apr 9, 2024 at 3:45 PM
    Cthur
    Got sensor fixed Still no crank, guess imma pull intake this weekend and make sure starter wiring didnt get messed up? No clue what else to try
  15. Apr 25, 2024 at 4:00 AM
    Cthur
    Are these grounds on the correct place or are these even grounds
  16. Apr 25, 2024 at 6:24 AM
    White with black strip is always ground. Hold on let me find a clearer picture to show where that ground should be. It looks about right.
  17. Apr 25, 2024 at 6:31 AM
  18. Apr 25, 2024 at 1:59 PM
    Cthur
    10 4 yah so its not the wires on top of my driver cylinder head..ill get intake off next week and investagate the starter wiring
  19. Apr 25, 2024 at 3:00 PM
    There's also a ground from the back of your block to the firewall, just behind the passenger side head. And a ground from your battery to the fender wall.
  20. Jul 10, 2024 at 4:43 PM
    Cthur
    Put new battery in just to check that.
    No luck
    Grounds seem good
    Still need to pull intake
    When i turn the ignition it unlocks my doors which i dont remember happening before
    It doesnt turn over or act like its trying either
  21. Jul 10, 2024 at 6:21 PM
    It’s been long enough I don’t remember this thread, and I don’t have a ton of time to read back, but I see you have a DC. Immobilizer was used in some DC specifically. Do you know if you have a chip key, or if there is/was ever an alarm installed? Are you using the original key?
    Cthur[OP] likes this.
  22. Jul 22, 2024 at 3:00 PM
    Cthur
    It did have alarm, not sure about either of the next questions i will test ny spare key.
    I dont have a fob for it.
    Sorry i have been crazy busy and lost energy for this project lately.
    Is there a way to scan it for an immobilizer?
    Edit forgot i lost my spare key in the last move
  23. Jul 27, 2024 at 10:40 AM
    Cthur
    From what i can tell i dont have an immobilizor , my keys are both just basic plastic. Not the rubberized style.
  24. Sep 12, 2024 at 2:06 PM
    Cthur
    Alright, fresh update is. I got it to crank over now, but it will not run.
    Cranking issue was a plug that had a broken clip on the starter
    Now that I got the battery charged up, it is just spinning over but, not firing over
  25. Sep 12, 2024 at 2:23 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Any codes?
  26. Sep 12, 2024 at 2:31 PM
    Cthur
    Edit at bottom
    No codes but battery was dead after all this so i charged it with my jeep.
    So may be codes when i get it to fire
    Edit: it was crank shar sensor not clicked in got an 0335 code right after i posted this response
  27. Sep 12, 2024 at 2:50 PM
    bfunke
    South Carolina
    Did you connect it?
    PS broken electrical connectors can be purchased from dealer and re-pinned - do not cut wires ever.
  28. Sep 12, 2024 at 3:28 PM
    Check your crank position sensor and its connector. Its harness often gets routed incorrectly during timingbelt change and will get rubbed thru by a pulley/belt. Once thoroughly nicked thru, the ECU gets no signal and won't engage the fuel pump. P0335 is a great clue.
    If you want to verify it's a fuel delivery issue like that, simple. Pop off the intake tube, spray some starter fluid (ether) into the throttle body. Pop the intake tube back on. Turn it over. If it fires, you're not getting fuel.
  29. Sep 12, 2024 at 4:18 PM
    Cthur
    Now its running it has a p0328 code and a p0051 code
  30. Sep 12, 2024 at 4:53 PM
    P0328 is what I keep popping. Indicative of harness problem with knock sensor (rodents) or faulty knock sensor. It's usually rodents. or broken/poorly attached knock sensor harness. P0051 is O2.
