06 Tundra Double cab electrical mystery
Discussion in 'Electrical' started by Bhopper06tundra, May 11, 2023.
  1. May 11, 2023 at 6:59 PM
    Bhopper06tundra
    Bhopper06tundra [OP] New Member
    Bruce
    06 double cab
    None
    I have an 06 Tundra double cab that has the 4.7 and I haven’t been able to find what’s causing the ig/ecu 10 amp fuse to keep popping. The truck runs in park and I can rev it up, put in gear ,depress brakes no problem. If I drive the truck even gently it pops the fuse less than 2 blocks from the house. This fuse popping makes it stop charging, no speedometer, abs light comes on. I’ve unplugged abs and it didn’t help. Any help would be appreciated! ​
