06 sequoia no start no crank
Discussion in 'Sequoia 1st Gen (2001-2007)' started by Stephen98, Aug 27, 2024.
  1. Aug 27, 2024 at 6:15 PM
    Stephen98
    Stephen98 [OP] New Member
    Need some help. I was on my way to work, get to a stop sign and the car cuts off. I tried to restart but I got no crank, no start and no click. I tried about 7 or 8 times and it turned over a few times and back to no start no click. I tried cleaning the cables,tested the battery and was still showing 12.5 amps after all attempts. The dash lights, head lights and radio all still work. I had someone to tell me to replace the switch, still nothing. Any ideas?
    Update. After reading about the anti theft i used the key to lock the door, waited about 15 minutes and used key to unlock the door-it cranked up. (At this point I'm proud of myself), put it in reverse, backed up a foot or two, pulled back forward and cut back off. Has anyone ever had this problem?
  2. Aug 27, 2024 at 7:14 PM
    koditten
    Kirk
    Midland of the Mitten
    Bad cell in the battery?
    Swap batteries and let us know if it still occurs.
    A bad cell drops the battery to ~10 volts or so. The ECU does not like less than 12 volts.
    Your truck sat for a bit and the voltage equalized over the 6 cells to give you 12 volts.( Each cell is 2 volts). There wasn't much capacity once started since 1 cell was in bad shape, so the truck died.
    Let us know what you find.
  3. Aug 27, 2024 at 7:22 PM
    Stephen98
    If the battery had a bad cell, shouldn't the alternator kept it running?
