05 Tundra engine
Discussion in '1st Gen Tundras (2000-2006)' started by andrewp, Nov 5, 2020.
  1. Nov 5, 2020 at 8:54 AM
    andrewp
    andrewp [OP] New Member
    good day to all, i need a little guidance on an 05 Tundra SR5- timing belt broke and damaged the engine- mechanic says replace timing belt, head set kit and bolts, head set gasket kit and thermostat. Other than the engine, the truck body is in good shape. Would it be better to replace the the whole engine or just these repairs? Also, can anyone put a value on it in current condition? about 210k miles, spray in bed liner and clean inside with little cosmetic defects.
    any help is appreciated.
    thanks.
  2. Nov 5, 2020 at 9:01 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Well, first off, welcome aboard.. I would buy a used engine and swap it out, as opposed to putting the same amount of money/labor/time into rebuilt heads and new gaskets. Keep in mind the piston tops probably have some dingers as well..
    what is the quote for all the work? Is it a truck you'll want to drive long enough to recoup the investment?
    you should be able to purchase a decent engine in the 900-1500 dollar range.
    You've got some ciphering to do...
  3. Nov 5, 2020 at 9:54 AM
    andrewp
    thanks for the reply! repair estimate is around $5200- im not much of a mechanic but know there is a good bit of labor involved in the rebuild. I plan to sell with or without repair- just trying to get a good idea of the best route.
  4. Nov 5, 2020 at 10:09 AM
    41bigdawg
    41bigdawg Let the BIG DAWG Eat
    Robert
    Tennessee
    2013 Tundra DC 5.7
    Magnum front, Iron Cross rear bumpers, SB Cold air intake and Gibson Metal Mulisha exhaust, Fender flares, Tow mirrors, 18" Outlaw wheels, 12k Smitty X2O winch, Tech 12v auto start, Firestone Air Bags, Pedal Commander, Devil Horns, etc...
    I would just sell it as is and walk away and go find another good truck. There is no telling the damage that was incurred without tearing it all the way down ie...rods, rod bearings, pistons, cylinder walls etc.. You could put a different engine in it but they are not cheap and you have no way of knowing if it is good or not. Either way you go (rebuild or used engine) you are putting half of what the truck is worth into fixing it. Just my thoughts.
  5. Nov 5, 2020 at 10:25 AM
    andrewp
    thanks.
  6. Nov 5, 2020 at 4:57 PM
    035VZFE
    035VZFE Restored a Tundra top to bottom
    James
    Vero Beach, Florida
    2009 Passat B6 2.0 Turbo
    ECS Tuning DV Spacer ECS Tuning Turbo Muffler Delete ECS Tuning Luft-Technik CAI System A-Spec 60mm Charge Pipe Straight piped from resonator back, stock cat and downpipe
    LS SWAP IT!
    Twin Turbos
    Ssskrrttt!!!!
    Hooptytrix and 41bigdawg like this.
  7. Nov 5, 2020 at 5:10 PM
    TundraBike&SkiGuy
    TundraBike&SkiGuy So I got that goin' for me
    Jeff
    Minneapolis, MN
    2020 Quicksand Tundra
    In July I sold my 04 Limited plus topper with 198,000 miles for $5500. It was in fair condition and mechanically sound except the AC did not work. The timing belt had not yet been replaced and that was a big concern for most buyers. The kid who bought it fixed the AC and did the timing belt right away. Probably a good thing based on the mileage of your timing belt crumple.
    Walk away and take what you can get for it.
    Hooptytrix likes this.
  8. Nov 6, 2020 at 4:02 AM
    Professional Hand Model
    Hand Protectors
    New used engine might be in order. BTW, why did your timing belt break?
  9. Nov 6, 2020 at 4:51 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    :hattip:If you do not plan to keep to the truck either way, cut your losses, save yourself the aggravation and stress and move on. Replacing the engine would be the best option but it ultimately may cost more than present quote. Used engine will need timing belt replacement, tune up, address the exhaust recirculate emissions crapola etc.
    That’s my budget of advice for today, the whole 2 cents. I guess I have to go back to being a clown the rest of the day. :hattip:
    Darkness likes this.
  10. Nov 6, 2020 at 5:05 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Good luck with your project . . .
  11. Nov 6, 2020 at 5:41 AM
    Sell it, don't go through the trouble of engine swapping. Most jobs take longer and cost more than the initial estimate. Value will decrease with an engine swap as well. Scares a lot of people off. I personally would go the LS swap route if my engine blew. My truck has very few electronics to mess with. Could just LS swap, lift and reharness the truck for less than $5200. Of course I would have to do the work.....
  12. Nov 6, 2020 at 7:55 AM
    Hooptytrix
    Dirty South
    Considering we are still in a global pandemic with future uncertainty, should you be buying a newer vehicle? I guess if you’re financially ok I think there are some really good deals to be had in the new trucks at the moment, used cars are seeing a higher than normal market. If you’re not to comfortable with the financials looking into the future, I would say budget around $8-10k and invest in what you have. I’m assuming you already own it outright so insurance is cheaper. This option can net you 10 more years with little maintenance costs.
