05 Double Cab headlights help
Discussion in '1st Gen Tundras (2000-2006)' started by 2bak, Jan 19, 2021.
  1. Jan 19, 2021 at 10:02 PM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Team-
    Looking to replace my 2005 Tundra Double cab headlight assembly. Stock has yellowed and rather than the polish route I think the truck deserves a fresh set. Having a tough time tracking down a set of OEM. Can anyone help? The access cab set seem to be out there but that apparently is different than I need for the DC. Thanks.
  2. Jan 19, 2021 at 10:59 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Local junkyard or online if you want oem. Or you can do an depo or tyc assemblies off eBay and Amazon.
    And yes the double cab lights are bigger and different
  3. Jan 20, 2021 at 4:32 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Had Depo brand on my Tahoe. Quality was not too bad. It was a good base for a mini H1 retrofit.
    Riverdale21 likes this.
  4. Jan 20, 2021 at 7:06 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    I bought new OEM from dealer. Shop around because prices vary by 20%. Going to have my truck for the long haul, so worth it to me to spend $400 on new.
    2bak[OP] and 06tacomadc like this.
  5. Jan 20, 2021 at 7:30 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Numbers at the top of the box are complete light/bulbs. Ones at the bottom are just the housings.
    2bak[OP] and trueblue1981 like this.
  6. Jan 20, 2021 at 9:37 PM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Hey thank you sir. Trying to look up an online source for this, any recommendations?
  7. Jan 20, 2021 at 10:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @Roman is a good place to start.
  8. Jan 20, 2021 at 10:46 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Headlamp Components for 2005 Toyota Tundra | toyotacool (toyotaofcoolsprings.com)
    Being TOCS sales store is down, maybe try Sparks..
    Headlamp Components for 2005 Toyota Tundra | Sparks Parts
    When I had my 2005 DC, I buffed the headlights out with a rotary pad on a drill and Flitz polish.
    It worked pretty good...
    Just be careful to what your drill speed is..
    I use a DA polisher for that work now..
    Flitz HR31501 Headlight Restoration Kit | JB Tools
    Amazon.com: Flitz HR 31501 Headlight and Plastic Restoration Basic Kit: Automotive
    Did the then daughter's car as well..
    48F23F58-1D91-46DA-B302-F911ABB57C8E_zps_15847fe6ff200c89aed7b460fbaae43433c151d1.jpg
    2bak[OP] likes this.
  9. Jan 21, 2021 at 4:44 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Not really. If you go to https://parts.toyota.com/ it will list your closest local dealers.
    Otherwise I typically just use TYC brand housings from RockAuto or Amazon.
    2bak[QUOTED][OP] likes this.
  10. Jan 21, 2021 at 7:38 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Aftermarket ones are plenty fine IMO. You’ll spend a 1/4 of the cost and years out of them. I use them for my retrofit builds and have only had one issue out of the 30-40 sets I’ve built.
  11. Jan 21, 2021 at 9:42 AM
    2bak
    2bak [OP] Thanks
    M
    Bellingham WA
    2018 CM
    Dig it. You have an aftermarket you trust more than the rest?
  12. Jan 21, 2021 at 9:57 AM
    SouthPaw
    2000 Limited 4x4 AC
    If I had to guess, there is only one or two manufacturers making them so I don’t think you can go wrong.
  13. Jan 21, 2021 at 11:00 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    My experience with aftermarket housing is that that cutoff line is much less pronounced. In fact I would happily trade these shiny aftermarket mismatched set for some ok condition OEM that need to be polished.
  14. Jan 31, 2021 at 10:32 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  15. Jan 31, 2021 at 10:58 AM
    Professional Hand Model
    Hand Protectors
    Cheap Chyna LED Bulbs with Cheap Chyna Aftermarket Housing Assys (bottom pic 23ft. test).
    Best light the truck has ever had. Only thing left for me to try are Projectors of which I’ll be doing the Morimoto MLED 2.0.
    Or, I may try these Morimoto 2Stroke 3.0 Bulbs as they’ve gotten great reviews.
    2005/06 Tundras are finicky with LED, though.
    HBTundra likes this.
  16. Feb 4, 2021 at 7:55 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Depo head light assemblies from Rock Auto with SuperbrightLED CAN LED heads and fogs. Still running factory fog lenses and need to change them out.
  17. Feb 5, 2021 at 3:50 AM
    Hand Protectors
    A Headlight and Fog Duel! AC vs. DC
    Katanas Headlights with SuperNova High Dolla Fogs in the sweet Wrap Around Chrome Bumper Factory Fog Assys with 270° spread.
