040 Daily Driver Project Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by trayday, Jan 19, 2018.
  1. Jan 19, 2018 at 3:12 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    My first major mod was to supercharge or lift. I didn't want to pay for premium fuel so I decided to install the 7" BDS lift w/ Bilstein 5100 shocks, 20x10 Fuel Mavericks with 35x12.5 Terra grapplers.
    List of current mods- Custom length ADS 2.5" coilovers w/res, modified TC UCA's, custom length Coach Builder tie rod ends, ADS rear shocks 2.5", TRD rear sway bar, ESP under seat storage, diff breather mod, home made SABM with AFE dry filter, N-Fab hoop steps, PRO grill and shift knob, Hyper Tech calibrator.
    CringyDad likes this.
  2. Jan 19, 2018 at 3:14 PM
    trayday
    Oregon
    2015 limited CM 5.7
    horsefall1.pnghorsfall.jpgTaking the trials at the beach
    TRD15559 likes this.
  3. Jan 19, 2018 at 3:27 PM
    trayday
    Oregon
    2015 limited CM 5.7
    20180114_112315.jpg Air compressor with tank, 4.88 gears, ARB locker, air bags and driver side half shaft 20170831_163522.jpgHaving these installed along with custom length Deaver K37 springs and FOA bump stops. Found the Kings on CL for $450.
  4. Jan 19, 2018 at 4:08 PM
    trayday
    Oregon
    2015 limited CM 5.7
    20180114_111851.jpg 20180105_164800.jpgESP storage and LED lights in the cabin.
  5. Jan 19, 2018 at 4:12 PM
    trayday
    Oregon
    2015 limited CM 5.7
    20170504_172534.jpgATTACH=full]112952[/ATTACH] IMAG1264.jpg IMAG1265.jpg IMAG1267.jpg N-Fab RSP bumper with SmittyBilt winch, LED bar. Bumper mounting holes didn't line up with the bracket bolts on the truck frame. N-Fab and the vendor weren't much help so I had to have the holes moved in about 1/16" on both sides. The Winch control box didn't fit attached to the winch mount while attached to the bumper. I had to have brackets made to attach the control box to the bumper.
  6. Jan 19, 2018 at 4:45 PM
    trayday
    Oregon
    2015 limited CM 5.7
    bushings.jpgI would throw the wheel alignment after any decent sized hit and the truck would make a knocking noise when making sharp turns at an almost stand still. Ended up being my steering rack bushings so I replaced with poly. The dealer wanted $2700 to replace by pulling the motor and an independent shop wanted $900. I ended up paying $350 to a fabricator, notches were made for easy access incase they need replaced again. The skid plate has also taken a beating.
  7. Mar 5, 2018 at 9:53 AM
    trayday
    Oregon
    2015 limited CM 5.7
    12028.jpg 12025.jpg 12026.jpg Progress. Extended sway bar links, rear brake line extensions, seconday and bump shock brackets, bump plates and new D/S half shaft.
