04 Tundra - Power Steering Rack Leak
Discussion in '1st Gen Tundras (2000-2006)' started by Kraska13, Jul 31, 2021.
  1. Jul 31, 2021 at 5:07 PM
    Kraska13
    Kraska13 [OP] New Member
    2004 Toyota Tundra TRD
    Hey folks. It's obvious I have a significant leak from the power steering rack. I tried using the Stop Leak fluid but with zero luck.
    Has anyone replaced the rack themselves? Dealer wants $1500 to replace. Local shop wants $1300. Any suggestions? I've replaced a decent amount of things on this Tundra and my former Tacoma but haven't heard of anyone doing this one themselves. Am I in for a slough of swear words and a headache or is this a doable project?
    CandleSmoke and YardBird like this.
  2. Jul 31, 2021 at 5:12 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had this happen when I first got my '04. Turned out to be that one of the supply lines was bad, and easily replaced,
  3. Jul 31, 2021 at 5:14 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Good luck with your issue.
    FrenchToasty likes this.
  4. Jul 31, 2021 at 5:17 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would do it myself. Ordering a new OEM rack online from the dealer is typically around $500. I guess it all depends upon how you feel about removing the existing plumbing. Is there a lot of rust on the underside?
  5. Jul 31, 2021 at 9:16 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    I had mine partially out when I replaced my lower control arms. I Think I could handle the rest of it. Only thing I'm worried about is breaking a rusty fluid line.
    Jack McCarthy likes this.
  6. Aug 1, 2021 at 8:36 AM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    https://www.youtube.com/watch?v=vvvCWN0pQwg
    If you're capable, a new OEM rack and replacing it yourself is by far the best option. Just be aware there's two versions, one for about $400 and one for about $700 IIRC. Hopefully you have the half-price option. I think the difference may be AC vs. DC.
  7. Aug 1, 2021 at 11:03 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Replacing the steering rack is actually pretty easy on these trucks, especially if you've done other work on the truck. Remember to center the rack before installing and count how many rotations the tie rods have to get the alignment close. I went with the detroit axle rack with lifetime warranty when you send your rack back in the prepaid box. Had it on for 2 years or so and its been perfect.
    https://www.detroitaxle.com/shop/st...ck-and-pinion-assembly-toyota-sequoia-tundra/
    CandleSmoke and des2mtn like this.
  8. Aug 1, 2021 at 2:26 PM
    ToyotaJim
    ToyotaJim New Member
    I just had this done last month. I might have slightly overpaid, which is annoying. I paid $1780 + tax.
    Power steering pump, rack and pinion, mounting bushing, steering gear, alignment, and labor.
    CandleSmoke likes this.
  9. Aug 2, 2021 at 2:04 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I've slowly started looking into this also for my 2003. The prices you listed are about what I was quoted.
    I think depending on how bad the leak is, you can probably let it go for a bit. Mine doesn't leave any evidence on the ground, so I'm not in a rush. So you might be able to wait a bit if needed.
    But, as I was looking into this; I think you are better off trying it yourself and getting an oem rack. I would also consider lower control arms (or just bushings) while you're at it. That's what I'm looking to do when I finally tackle this.
