04 Tundra Differential Help
Discussion in '1st Gen Tundras (2000-2006)' started by gwbsr7498, Apr 17, 2021.
  1. Apr 17, 2021 at 11:37 AM
    gwbsr7498
    gwbsr7498 [OP] New Member
    2004 Tundra 4dr 2wd 4.7L 8c
    Hi folks. Here are the main points; Appears I need to replace the rear end on my 04 Tundra after 220K miles. Mechanic I (semi) trust identified the issue. Said metal shavings were found in the gear oil and it’s best to replace the entire rear end. He uses LKQ for parts but they don’t have a matching differential. He’s a smaller family operated shop and busy so it will take him time to continue searching but I can help and provide it to him to install. This is beyond my mechanical knowledge and ability so I need help please. I don’t know what to look for or where. Suggestions from this community? I’ll try to answer any questions - there is a little info I’ve left out so as to keep this brief.
  2. Apr 17, 2021 at 11:40 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Welcome to the forum and thank you for your service!
    LKQ is a good source for used parts. You can also try calling local automotive scrap yards to see if they have any decent used ones... or craigslist.
    Voss and gwbsr7498[OP] like this.
  3. Apr 17, 2021 at 2:32 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Voss and speedtre like this.
  4. Apr 17, 2021 at 7:57 PM
    gwbsr7498
    This is great. Thank you, Sir!
  5. Apr 17, 2021 at 8:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    May be worth calling around to differential shops. Possible you can have it rebuilt with a new ring and pinion for cheaper than a whole new rear end.
    my experience with used diffs have been... spotty. Rebuild by a reputable shop will likely outlast the truck if taken care of
    speedtre and dbittle like this.
  6. Apr 18, 2021 at 1:04 PM
    gwbsr7498
    This is good information, thank you. I’ll look to see what I can find locally.
  7. Apr 18, 2021 at 3:02 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    What area are you in? Maybe someone can suggest a place to have it done.
    If you we're near me and can pull the 3rd member, I could do it if you're not in a rush.
    Voss and MS22 like this.
  8. Apr 18, 2021 at 4:21 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Do you need the whole assembly or just the 3rd member?
    There's a few places out there that sell the 3rd, ECGS being the first to mind https://eastcoastgearsupply.com/
    Voss, bmf4069 and speedtre like this.
  9. Apr 19, 2021 at 5:00 PM
    gwbsr7498
    I’m in the Midland and Odessa area of west Texas. A bit far from you I think but I do appreciate that offer. I need to get it completed by mid summer. My son will be leaving for college in Houston this fall.
    bmf4069 likes this.
  10. Apr 19, 2021 at 7:57 PM
    gwbsr7498
    I am much better under the hood and with older model vehicles. I’m not ashamed to admit my lack of skills and knowledge in this area. I have no idea other than what the mechanic said - the entire assembly needs to be replaced. He tried explaining why but again, I’m lacking this skill set. I’d thought (may sound silly to some) that it may be best to replace the entire assembly as opposed to trying to join parts that were not manufactured together. Any specific direction y’all can provide on that would be great. Especially knowledge on the Tundras. I found an 03 Tundra rear end but I’m not sure if it’s compatible with my 04. Both are 2wd.
  11. Apr 19, 2021 at 8:17 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I'm up in amarillo, and @MrDirtjumper is from your neck of the basin.
    gwbsr7498[QUOTED][OP] likes this.
  12. Apr 19, 2021 at 8:45 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I would offer up the rear end from my parts truck but I crawled under it the other day and noticed both axle seals are leaking. If you factor in replacing those seals, you’re likely better off just replacing the whole rear end from a pick and pull.
    I know for a fact there’s a DC with a LSD with under 200k in the pick and pull here. The truck as a whole looked very well maintained. You might give them a call and see what they want for it. Clarks Auto in San Angelo.
  13. Apr 20, 2021 at 4:09 AM
    Professional Hand Model
    Hand Protectors
    Is the truck driving bad? Mechanic found shavings? As in big shtuff or like a fine dust on the magnet? Fine shtuff is ok.
    Curious as your symptoms.
  14. Apr 20, 2021 at 5:26 AM
    gwbsr7498
    driving is not bad (as in handling). Heavy/rough sounding road noise while in motion. If considering driving on a rough or grooved pavement, this would be significantly amplified - even on new pavement. Mechanic found pieces larger than shavings but not huge pieces.
  15. Apr 20, 2021 at 5:31 AM
    gwbsr7498
    Thank you for the offer and lead. I’ll definitely give them a call and check out the possibilities. This inquiry is giving me good results. Y’all are very helpful. Thanks again! There’s a place out here called Citrons and everyone I’ve spoken to has told me to steer clear. I’m sure I’ll have to get further out. San Angelo is certainly not far.
