'04 Transmission Into My '00
Discussion in '1st Gen Tundras (2000-2006)' started by Somemedic, Feb 25, 2018.
  1. Feb 25, 2018 at 8:22 AM
    Somemedic
    Somemedic [OP] New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Finally got a chance to have the shop swap the transmissions. My current trans had 113K on it. Seemed alright but from what I'd read on the forums the 03-04 transmissions were revamped and more robust. The unit was purchased out of a boneyard in Kenosha from car-parts.com. Less than 50K on it for $400 plus $125 to bring it right to the fire station.
    The good guys at National Trans in Portage flushed and replaced the filter and made the swap for $700. Its very tight and quiet. Couldn't be more pleased.
    Towing the camper or bass boat won't be concern. I should be good for awhile.
    Filthyphil and 831Tun like this.
  2. Feb 25, 2018 at 5:38 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Good to hear! That’s what I plan on doing if mine bites the dust, currently have 152,000 on it and doing a drain and fill next weekend. Did they have Anything special they had to do for the swap or was it easy direct swap?
  3. Feb 25, 2018 at 8:03 PM
    Somemedic
    Mark
    This is a direct swap...only the internals and fluid type are different
    Filthyphil likes this.
