03 tundra stalls after replacing battery terminal
Discussion in '1st Gen Tundras (2000-2006)' started by Rrworker, Apr 14, 2018.
  1. Apr 14, 2018 at 4:56 PM
    Rrworker
    Rrworker [OP] New Member
    2003 Tundra SR5
    New member in Alabama. I noticed my clock kept resetting overnight for about a week so yesterday I cleaned up the positive battery terminal, and went to work, 23 miles one way, the truck stalled twice at the red light, while cleaning up the terminal I saw that it was deteriorated so today I replaced it with a standard terminal, drove it and it's doing the same thing. I read earlier this could require resetting the Ecu, anyone experience this before? I thought it might be a bad alternator, it's got 270,Xxx miles on it.
    TXRailRoadBandit73 likes this.
  2. Apr 14, 2018 at 5:04 PM
    Welcome from Texas
  3. Apr 14, 2018 at 5:08 PM
    Have your battery and alternator checked?
  4. Apr 14, 2018 at 5:15 PM
    Rrworker
    2003 Tundra SR5
    The battery is 8 months old, no problem with it running until I removed and cleaned the terminal.
  5. Apr 14, 2018 at 5:17 PM
    Take alternator to get tested?
  6. Apr 14, 2018 at 5:20 PM
    Rrworker
    2003 Tundra SR5
    No......it's pouring down rain and don't want to be stranded on the side of the road .
  7. Apr 14, 2018 at 5:24 PM
    Get it tested when u have time, I have a '97 T100 with 305550 miles the dash battery light was coming on, took to autozone get tested both batt and alt were bad but I replaced with alt, no more issues, my batt is a Interstate bout 3 yrs old
  8. Apr 14, 2018 at 5:27 PM
    What's your username mean?
    831Tun likes this.
  9. Apr 14, 2018 at 5:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome Chris. There may be a bad connection at the other end of the battery cable. The alternator is also suspect. Check all your connections carefully and I like to use No ox or something like this:
  10. Apr 14, 2018 at 5:30 PM
    Rrworker
    2003 Tundra SR5
    I'm thinking it's something to do with taking the battery terminal loose. However, I've done that before when cleaning the terminals and replacing the battery and haven't had the problem. I took them off last night and this morning is when it was acting up.
  11. Apr 14, 2018 at 5:32 PM
    The terminals from the truck are stock? Or replaced em?
  12. Apr 14, 2018 at 5:36 PM
    Rrworker
    2003 Tundra SR5
    No meaning, easy to remember
  13. Apr 14, 2018 at 5:36 PM
    Ha! Was thinking Railroad worker lol
    CaptainGrumpus likes this.
  14. Apr 14, 2018 at 5:37 PM
    Well hopefully it gets resolved quick, others on here will chime in to assist
    Bob likes this.
  15. Apr 14, 2018 at 5:43 PM
    Rrworker
    2003 Tundra SR5
    Lol, I hope so. I'll visit advanced tomorrow unless someone can help with this reset.
  16. Apr 14, 2018 at 5:46 PM
    Rrworker
    2003 Tundra SR5
    Yes, they were stock. I noticed the positive one slightly broke / deteriorated and replaced it today, same problem .
  17. Apr 14, 2018 at 5:48 PM
    Rrworker
    2003 Tundra SR5
    You a railroad worker?
  18. Apr 14, 2018 at 5:51 PM
    Yes, Union Pacific and another member on here from Ohio works for CSX
  19. Apr 14, 2018 at 5:57 PM
    Rrworker
    2003 Tundra SR5
    Cool, you know what a draft gear is ?
    How about a slack adjuster?
    ABD service valve?
    Lol
  20. Apr 14, 2018 at 6:00 PM
    ..............mmmmm....no
    What u do?
  21. Apr 14, 2018 at 6:09 PM
    Rrworker
    2003 Tundra SR5
    Yes, parts on a railcar .
  22. Apr 14, 2018 at 6:15 PM
    We I stall ties under rail, surface and line rail too, so I know nothing of rail car parts
  23. Apr 14, 2018 at 6:24 PM
    Rrworker
    2003 Tundra SR5
    I gotcha. Can you drive a spike?
  24. Apr 14, 2018 at 6:27 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Clean your MAF sensor. It can cause stalling at idle especially after a battery disconnect.
  25. Apr 14, 2018 at 6:49 PM
    Rrworker
    2003 Tundra SR5
    Ok I'll check it.
  26. Apr 15, 2018 at 10:03 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA. I hope you find the root cause.
  27. Apr 17, 2018 at 10:04 PM
    Jackson
    Jackson New Member
    Theron
    WY
    2001 Black Tundra SR5 AC
    MAF sensor?? I disconnected my battery on my 2001 tundra to try and clear an ABS light on the dash and it worked, but now it runs like crap. When it starts, it idles up to 1000 - 1100 (like always) and then instantly starts to idle down to 500. I try and rev it, but it's like the more I give it gas the worse it gets. I just replaced the fuel filter thinking that it was plugged and no luck. Still the same. So, is the MAF sensor in the top of the air cleaner box? And, can I use contact cleaner (LPS Micro-X NU) that is safe on plastics?
  28. Apr 18, 2018 at 2:54 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Correct on the location, not sure on the cleaner since MAF cleaner is cheap enough. I wouldn't risk it considering a new sensor is about $60.
  29. Apr 18, 2018 at 3:09 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    A lot of Toyota's will stall at idle after you disconnect battery. This is from a dirty throttle body. Clean your throttle I bet you'll be fixed.
  30. Apr 18, 2018 at 4:00 AM
    Jackson
    Jackson New Member
    Theron
    WY
    I will get some cleaner and clean it. Thank you.
