03 tundra lift options
Discussion in 'Suspension' started by Sandman411, May 26, 2024.
  1. May 26, 2024 at 7:29 PM
    Sandman411
    Sandman411 [OP] New Member
    I currently have an 03 tundra with a 5"ruff country lift. This lift was on the truck when purchased. I'd like to get rid of the coil spacers but I can't seem to find a good set of 6" lift coilovers. Any suggestions?
  2. May 30, 2024 at 10:57 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    6 inches is a lot for these trucks. 3 inches is more standard without having to make major modifications. What are you looking to do with your truck? Why do you want 6 inches of lift?
  3. May 30, 2024 at 11:05 AM
    He has a 5” (presumably bracket lift) already installed. Usually uses a bolt on spacer on top of the factory strut assembly. He’s wanting a longer than factory strut assembly to take the place of that. Someone like King, Fox or maybe even the Rough Country N2s may have a solution.
