03 Tundra high pitched whistle while truck is off!
Discussion in '1st Gen Tundras (2000-2006)' started by Rhondavu, Nov 17, 2019.
  1. Nov 17, 2019 at 6:05 AM
    Rhondavu
    Rhondavu [OP] New Member
    Rhonda
    03 Tundra SR5
    This morning I woke up to what I thought was "ringing in my ears" only to later find out that ot wasn't me but my truck out front making this very high pitched constant whistling under the hood. Almost the sound of a boiling kettle that whistles on the stove. I cranked her up but it did not stop. I disconnected positive terminal and it stopped. As soon as I reconnect...it starts back. The sound is very concentrated between battery box and driver dash. Any clues out there for me to troubleshoot? I haven't done anything mechanical recently that i would have caused a side effect.
  2. Nov 17, 2019 at 6:07 AM
    speedtre
    speedtre New Member
    Inland Northwest
    A recording of the sound would help greatly in troubleshooting if you can record and post a short video...
  3. Nov 17, 2019 at 6:28 AM
    SouthWestGA
    SouthWestGA New Member
    Bad relay somewhere?
  4. Nov 17, 2019 at 7:29 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Just checked my 2004 and the location of a chirp sound when I use remote to lock(1 chirp) or unlock(2 chirps) comes from that location or maybe more in area of brake fluid reservoir. If I could turn that chirp into a constant sound, it could definitely be construed as a high pitched sound. That said, could it be the chirp/beep horn? shorted on for some reason !
    N84434 and Rhondavu[QUOTED][OP] like this.
  5. Nov 17, 2019 at 7:36 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Start pulling fuses until it stops. That'll get you in the ball park.
  6. Nov 17, 2019 at 7:40 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    That's probably the best guess. Should be on the fender little round doodle, possibly wrapped in foam.
    Rhondavu[OP] likes this.
  7. Nov 17, 2019 at 8:02 AM
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    had the same problem after i went mudding pulled the negative terminal left it over night and the ringing stopped has not started up again
  8. Nov 17, 2019 at 10:47 AM
    Rhondavu
    Rhonda
    03 Tundra SR5
    Bubba and Fester....you guys steered me in the right direction! “Round doodle wrapped in foam” by the brake reservoir was spot on. With truck off, I tightened battery terminal back on and the screaming started. I went straight to the round doodle, disconnected it and instantly the screaming stopped! What’s the name of that part as I would like to replace it? Thanks so much for the help.
  9. Nov 17, 2019 at 10:50 AM
    Professional Hand Model
    Hand Protectors
    Thats ‘el Piezo’.
    Pinay likes this.
  10. Nov 17, 2019 at 11:30 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    2004 FSM refers to it as a Wireless Door Lock buzzer
  11. Nov 17, 2019 at 11:36 AM
    Festerw
    Festerw New Member
    04 Tundra DC
  12. Nov 17, 2019 at 11:41 AM
    Hand Protectors
    After this problem gets fixed and as a side note: I taped over that hole in the Piezo with a small piece of blue tape to dampen the ‘chirps’ when using FOB to lock/unlock. The Piezo is too loud IMO, and the blue tape dampens to shrillness down to a silent click sound.
    Below is for my 2002, but is in the parts search for years 2000-04.
    Make sure you post up your fix solution whatever it may be.
    Pinay likes this.
  13. Nov 17, 2019 at 11:42 AM
    Hand Protectors
    Pinay likes this.
  14. Nov 17, 2019 at 11:43 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Perhaps every part does not have part number on it but I’d be surprised not to find a number and possibly words Denso if you took foam off
  15. Nov 17, 2019 at 11:47 AM
    Hand Protectors
    The reviews look good on the Floyd Bell. All types of Toyota users saying good things.
    Pinay likes this.
  16. Nov 17, 2019 at 11:49 AM
    Hand Protectors
    Might be another issue though causing the sound. Old Battery maybe? I know every time my security system starts acting up its caused by a dying battery.
    Pinay likes this.
  17. Nov 17, 2019 at 11:50 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Mine actually looks like a tombstone but I'm not entirely sure it's stock for a Tundra. It also stops working when it drops below 20 and the plan is to replace it with what I linked above.
  18. Nov 17, 2019 at 11:53 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yeah, my comment was more to do with if it had a part number, does it google it indeed as a piezo/buzzer and nothing to do with Floyd Bell quality
  19. Nov 17, 2019 at 11:56 AM
    Hand Protectors
    I think my security system VP3000? is aftermarket dealer installed. Try searching with a local stealership and it pops up.
    marbleville and Pinay like this.
  20. Nov 17, 2019 at 2:46 PM
    Rhondavu
    Rhonda
    03 Tundra SR5
    As a new member on the forum....it was a successful and positive experience. In fact it’s the only forum I’ve ever participated in. Thanks to everyone for the collective info and sending me parts name.
    RPR and Professional Hand Model like this.
  21. Nov 17, 2019 at 2:49 PM
    Hand Protectors
    Let us know how it all works out. We might end up having the same problem.
  22. Nov 18, 2019 at 2:25 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    My old '03 did the same thing, I just unplugged it.
  23. Nov 19, 2019 at 8:49 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    @turtles872 hey Turts MaGerts, check out this thread for your noise issue
    bmf4069 likes this.
  24. Nov 19, 2019 at 2:02 PM
    turtles872
    turtles872 New Member
    Tish
    2003 Tundra
    Thanks a bunch French Toasty!! This was great info and will try unplugging tomorrow morning in daylight!! I hope it works because that noise is so aggravating!
    FrenchToasty likes this.
  25. Nov 19, 2019 at 2:48 PM
    Hand Protectors
    Report back with info or we’ll send @marbleville AKA ‘Marbles’ to hunt you down.
    marbleville likes this.
  26. Nov 19, 2019 at 5:17 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    Sorry Fred but my resource for tracking down people passed away about 10 years ago - my Dad. His last posting while in the service was as the head security officer in charge of base security at the Trident Submarine base, Bangor, Washington. Following up on this, after retiring from the Navy, he took a position with the U.S. Marshals Service before starting his own security service in Oregon. I benefited from his connections a few times, though it was sort of improper (possibly illegal). But family is family, and one does what is necessary when the cause is just. It was through him that I learned almost EVERYONE has a file on them somewhere in the federal database, with the exceptions being rare.
    I'll just have to pass on this hunt, as justified as it would be for not following through with a report, in triplicate and double spaced - notary not required!:spy:
  27. Nov 19, 2019 at 6:55 PM
    marbleville
    Yep, last name too.
    State of Confusion
    Yep, I think you are right. Mine was not installed at the "factory" but rather at the "port", according to a small booklet on the VP3000 that came with the owner's manual. Yet there is a little bit of doubt, as the manufacturer's sticker that also came with the truck states the alarm was installed at the factory. Here's the rub...that same sticker says I have 60/40 seats in front, when in reality I have captain's chairs.
  28. Nov 2, 2020 at 12:13 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Same thing happened to me this morning; annoying as hell. Good info in this thread; I'll have to look for that piezo buzzer in my 02 Tundra as well and disconnect it.
    I did notice that the dome light doesn't go on when either door is open like it used to do; only when you intentionally turn on that light via the switch beside it.
  29. Nov 10, 2020 at 2:12 PM
    Jack McCarthy
    Bill
    North of Boston
    Very bizzare....connected that piezo buzzer back up 3 days later and it now works. Even the dome light comes on, but the light on the bottom of the driver door stays off.
    The passenger door works fine too.
  30. Nov 12, 2020 at 9:03 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I had this happen on my 2003 AC . . . it got damp from the hood being cracked open over night. I unplugged it and it went away. I recently sold the truck to a friend and I was walking him through the truck and came across the the unplugged connection. I told him the story and plugged it back in . . . worked fine. I'd prob. recommend some dielectric grease on the connection to help prevent moisture intrusion.
