Electrical gremlins in reverse
Discussion in 'Electrical' started by 455h0le_dachshund, Feb 5, 2024.
  1. Feb 5, 2024 at 9:04 AM
    455h0le_dachshund
    455h0le_dachshund [OP] Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    I wasn't sure if I should post this in Lighting or Electrical.
    When I put my 03 Tundra in reverse, if my foot is also on the brake, then my right turn indicator glows solid on the dash, while my right front and right rear indicators also glow solid, and my right reverse light does not come on.
    If I take my foot off the brake, while in reverse, then the right signals turn off like normal.
    I don't know much about electricity. But I first noticed this about a month ago. :help:
  2. Feb 5, 2024 at 9:29 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    What do the wires look like? Any taps or splices?
  3. Feb 5, 2024 at 9:56 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Not on the tail light.
    I have never removed the front signal on this truck. I guess that's the next step.
  4. Feb 5, 2024 at 10:02 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    When I set the parking brake and take my foot off the brake pedal while in reverse, the reverse lights work like normal and the turn signal light goes away.
    So it's got to be related to the brake, I would think.
    No LEDs in the tail lights or front signals.
  5. Feb 5, 2024 at 12:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    check for blown bulbs first. like remove all the bulbs and add one back at a time. if the dual filament ones blow and the filament ends up touching the other one it causes all kinds of weird shit
    455h0le_dachshund[OP] likes this.
  6. Feb 5, 2024 at 2:22 PM
    Is this the truck that just got a backup camera?
  7. Feb 5, 2024 at 3:03 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    All the bulbs are operational. I even tried changing them all to new bulbs.
    Here's the newest development. I turned on the marker lights and the hazards...
    The right red marker light is blinking opposite of the right signal blinking.
    The truck looks like a police vehicle from one side o_O
  8. Feb 5, 2024 at 3:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Check the switch, see if power is bleeding over.
  9. Feb 5, 2024 at 3:08 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yes, but this issue isn't a new development. This has been going on for at least a month. The camera just went on yesterday, which is what reminded me, because at night I could see the amber light in the camera view
  10. Feb 5, 2024 at 3:09 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    How do I do that?
  11. Feb 5, 2024 at 3:10 PM
    Do you have one of the trailer harness adapters on this truck? Believe there was a tsb for some of the original Toyota adapters.
  12. Feb 5, 2024 at 3:24 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It has the tow package with 7 pin, if that's what you're asking.
    KNABORES[QUOTED] likes this.
  13. Feb 5, 2024 at 3:27 PM
    This package is probably a wire harness adapter that plugs in between the factory harness. Maybe you can unplug the tow harness adapter and plug the factory harness back together and eliminate the adapter to see if the problem still persists.
  14. Feb 5, 2024 at 3:29 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
  15. Feb 5, 2024 at 9:01 PM
    empty_lord
    05 rollover special
    i'd be looking at grounds in the back of the truck at this point. overloading a poor ground will lead to power finding ground in other places
  16. Feb 5, 2024 at 9:09 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup, I was gonna say the same thing, specifically the ground for the right side.
  17. Feb 6, 2024 at 10:06 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Problem solved. :muscleflexing:
    It was the OEM tow harness. Unplugged it and everything works now.
    I guess now I have to order a new one.
    landphil likes this.
