02 v6 swapped to a v8
Discussion in '1st Gen Tundras (2000-2006)' started by db99, May 30, 2019.
  1. May 30, 2019 at 6:52 AM
    db99
    db99 [OP] New Member
    Devon
    02 tundra access cab
    20x12 -44 offset on 35s
    I have a 02 tundra v6 and I was wondering if it was possible to take the v8 they made for that year and swap it and just bolt up to the v6 trans? Are they the same transmission or am I gonna have to swap the whole thing?
  2. May 30, 2019 at 6:58 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Both used the A340F/E (F = four wheel drive E = 2 wheel drive). I believe it was the 02 Tundra that had the weak planetary gear (not that many people had transmission problems, but it's really the only year/application of A340s that had any sort of poor reputation...they are a very reliable transmissions in general), so if you get a V8 from an 03-04 that comes with transmission cheap it may just be easier to swap it all out at once...just a thought.
  3. May 30, 2019 at 6:59 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I'm assuming your Tundra is an AT of course...:thumbsup:
    db99[OP] likes this.
  4. May 30, 2019 at 8:21 AM
    db99
    Devon
    Yeah sorry about that it’s a AT
  5. May 30, 2019 at 1:25 PM
    mnm
    mnm Old Guy...
    Mark
    Smithfield, VA
    2008 Tundra Limited 4x4 DC
    You may already know this but I would think you have to switch ECU's out as well....
    speedtre likes this.
  6. Apr 17, 2021 at 11:13 PM
    DaWhiteTundra
    DaWhiteTundra New Member
    Anthonee
    Sacramento, Ca
    White 2002 sr5 v6 Rwd
    Lsd, 5100’s all around, lift springs, 1inch rear block, extra leaf, 13wl caliper swap, slotted drilled rotors, ss brake lines, 27mm sway bar, rear addco sway bar,
    I’m not sure if you ever got around to trying this... but the problem I ran into trying to put an 04 v8 a340e trans into my 02 v6 was that the v8 trans didn’t have a kick down cable hole and the v6’s do.
