02 Tundra rear shock hardware (90105-A0013) size?
Discussion in '1st Gen Tundras (2000-2006)' started by buccirj, Oct 15, 2021.
  1. Oct 15, 2021 at 6:01 AM
    buccirj
    buccirj [OP] New Member
    2002 Tundra 4.7L V8 TRD SR5 4WD ext cab
    2.5" Rough Country Susp. Kit N3 Struts & Shocks
    Lost one of my rear shock absorber lower mount bolt during an outing. Can't find anywhere online what the metric size/pitch and length of the bolt is. Part No. 90105-A0013. Local dealer doesn't have them on hand so looking for the same bolt substitute at napa. Thanks.
  2. Oct 15, 2021 at 6:21 AM
    NetGnome
    NetGnome New Member
    NJ
    2003 RC V8 4wd, 2007 Sequoia V8 4wd
    Removed lots of rust.
    M12x1.25 63mm long. 22mm long shoulder. Flange on head and nut.
    Jack McCarthy, tvpierce and shifty` like this.
  3. Oct 15, 2021 at 9:50 AM
    buccirj
    Thanks man. How did you get the spec's? By the way, when I replaced the shocks, I found two different bolts between the two shocks. Does a washer go on the nut side by chance?
  4. Oct 16, 2021 at 12:09 PM
    NetGnome
    NetGnome New Member
    NJ
    I am cleaning up a very rusty 1st gen tundra.
    I just pulled the bolt from my bolt bin and measured it.
    I do not recall a washer on my rear shocks, but I only looked at the driver side bolt.
    The nut has a flange, but a washer would work as well.
