02 Tundra 4.7 Compression Test Question
Discussion in '1st Gen Tundras (2000-2006)' started by derryt98, Mar 31, 2024.
  1. Mar 31, 2024 at 7:12 PM
    derryt98
    derryt98 [OP] New Member
    Derry
    2002 Tundra SR5
    i tested the compression in my 02 4.7 and the compression was around 180-190 at 9-10 cranks. does that sound good? i read that it should be in the range of 142-192 i was wondering if i should have tested it at a lower amount of cranks or is the way i tested it sufficient?
  2. Mar 31, 2024 at 7:13 PM
    shifty` In South Dakota Trouble ain't hard to find
    I assume your compression tester captures the highest level of compression as with every one I've ever used, and thus, your compression looks great. But I also recognize I haven't used every tester on the planet, so yours may differ. Either way, I'd be happy with those numbers.
  3. Mar 31, 2024 at 7:27 PM
    derryt98
    Derry
    2002 Tundra SR5
  4. Apr 1, 2024 at 8:41 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    And I believe I've used the same tester as in the video. Stores the highest number, you're good.
