02 Sensor 1 Bank 1 problem
Discussion in '1st Gen Tundras (2000-2006)' started by Bungee, Feb 1, 2022.
  1. Feb 1, 2022 at 2:34 PM
    Bungee
    Bungee [OP] New Member
    2002 Tundra 4x4 Limited
    2002 Limited V8 original owner. As title says, the bank 1 sensor 1 faulted and took it to a mechanic to fix. They said they were unable to remove it and recommended me to a muffler shop.
    They told me the 02 sensor was placed at an angle and stripped threads.
    They gave me two options:
    1. Create a new area to place a new 02 sensor and leave the old one in place. Not ideal but much cheaper. $280
    2. Get new manifold, etc. $1200
    I went with option one and hoping and praying that it will work.
    I have been through about 4 02 sensor replacements with only 143k miles on it.
    Im not sure who or when this faulty sensor was last replaced.
  2. Feb 1, 2022 at 2:59 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    What brand are the replacement sensors? Denso seem to be the only ones that work and last.
  3. Feb 1, 2022 at 3:42 PM
    Something sounds squirrely about that. I don't understand why they can't get the carcass out, re-tap the bung, and install a new one? Sounds like you're working with a real crack squad, plus your original mechanic screwed your shit up but isn't taking responsibility.
    Jack McCarthy and bmf4069 like this.
  4. Feb 1, 2022 at 8:46 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Find a better/fabrication shop.
    They could weld on a new o2 sensor bung after removing the one. Carbide bit to hog it out, hole saw or plasma cutter. Many ways to fix it.
    FrenchToasty likes this.
  5. Feb 2, 2022 at 2:38 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  6. Feb 2, 2022 at 8:38 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Xactly
