02 AC 4.8 - Can valves be shimmed from the top?
Discussion in '1st Gen Tundras (2000-2006)' started by fishordie, Nov 6, 2024.
  1. Nov 6, 2024 at 12:41 PM
    fishordie
    fishordie [OP] New Member
    Earl
    East Texas Piney Woods
    2002 SR5 AC 2WD 210K Grocery Getter
    Middle of Timing Belt - Possibly Cam seals
    I have seen a post that says they can only be shimmed from top and another that said they are shimmed from bottom of the bucket. Just curious. If possible from top I may try it if a valve needs it while I have VC off. If not, I'm not even going there.
    This is a 2uzfe engine.
    UPDATE: I think the answer is they are adjusted under bucket.
    I also just noticed the FSM I have was showing a 5ZE-FE engine.
    thx
  2. Nov 8, 2024 at 7:23 AM
    shifty` I'm having daydreams about night things
