01toyotatundra -noise
Discussion in '1st Gen Tundras (2000-2006)' started by Kappa82, Jul 9, 2017.
  1. Jul 9, 2017 at 11:26 AM
    Kappa82
    Kappa82 [OP] New Member
    Brenham Texas
    Green 01'Toyoya Tundra
    Truck runs fine. I start truck but turn on ac. I hear like a humming noise ,real low. But it is noticeable. Have had ac in the truck for 1yr. Just got it going yesterday. The noise I can feel the humming. Not really loud. But it seem to be putting strain on the truck. I feel as if the truck runs sort of sluggish and weird when I turn the A.C. on. On top of that the low pitch ,vacuum sound. It sound like the noise you get when you turn when you are low on fluid. It not that loud but sound like that. Can anyone give some suggestions. Please.
  2. Jul 9, 2017 at 11:36 AM
    Ask @LOTSOFTOYS he is a toyota mechanic
    Kappa82[QUOTED][OP] likes this.
  3. Jul 9, 2017 at 5:26 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm confused... u added the a/c?
  4. Jul 9, 2017 at 9:25 PM
    Kappa82
    Brenham Texas
    No AC was not working. Relay and ac fuse under the hood. Got all the fix and plug the crankshaft sensor back up after I replaced the connector. Got the truck back running and turned on ac it was good. Then I hear this noise like a humming. Almost like a power steering noise. Idk. What you think. Ac and clutch work fine but when I push the button the truck goes in to this struggle mode and the noise
  5. Jul 10, 2017 at 6:45 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Seems like the compressor and clutch is making the noise?
