01 Tundra sudden mpg decrease
Discussion in '1st Gen Tundras (2000-2006)' started by The tundy, Jun 14, 2018.
  1. Jun 14, 2018 at 10:30 AM
    The tundy
    The tundy [OP] New Member
    2001 tundra limited
    Hey guys I’m new to this forum here. I just wanted to see if anyone would have an explanation for my truck. So when I’m driving around town I can average about 15-16 mpg but when I get on the highway last I checked I only averaged 13 that’s at 75 turning 2500 rpm no wind no hills just flat straight road. I used to be able to get 21.5mpg all day long at 75 mph with my old tires but now I have all terrains but I don’t think a different tread pattern would mess with it that much. I’m truly stumped on this no check engine light or anything either. Thanks
    avgguy and Black Wolf like this.
  2. Jun 14, 2018 at 10:32 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  3. Jun 14, 2018 at 10:34 AM
    The tundy
    2001 tundra limited
    Thank you!
  4. Jun 14, 2018 at 10:40 AM
    Casper421
    In the woods
    06 DC
    Did you change the size when you got the at’s? Also, which tires did you have before and what at’s did you get?
    because_wumbo-truck likes this.
  5. Jun 14, 2018 at 10:44 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Welcome aboard from AZ!
    A change in tires can impact more than tread differences. Did you get different load rated tires? If so, what is the weight difference per tire? Rims still the same?
  6. Jun 14, 2018 at 11:16 AM
    The tundy
    2001 tundra limited
    I stuck with the same size tire a 265/70r16 and still running the stock rims. honestly I don’t remember what the last tires were they were on the truck when I bought it some kinda highway terrains is all I know. Now I have Nitto Terra grapplers. The absolute best I’ve seen with the old tires was 24.5 mpg at 75 mph and now the absolute best I’ve seen lately with these new tires is just under 15 at 75 mph so I lost almost 10 mpg. To me that just doesn’t seem right.
  7. Jun 14, 2018 at 11:25 AM
    Casper421
    In the woods
    06 DC
    Terra grapplers are definitely heavier than any highway tire, especially if you got the LT tire. The added weight would hurt your city mpg’s more than highway. An almost 10 mpg difference is substantial. You might have a warped rotor or two that is creating drag. I would check if the rotor is rubbing on the pads.
  8. Jun 14, 2018 at 11:34 AM
    The tundy
    2001 tundra limited
    Thank you I did the brakes not too long ago. maybe 12k miles ago but I will check on that. actually for what I get in the city it’s about the same as they were before.
  9. Jun 14, 2018 at 11:39 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Terra grapplers are heavy. When I went to General AT2 LT tire I'm getting 11-12 at 75. But, they're way over sized and it makes the speedo off. I'm going 75 by the speedo but in reality and every GPS speedo I've used says I'm going 80. So, I slow down, LOL!!!
  10. Jun 17, 2018 at 9:16 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I've had my 2001 since new, currently at 87k miles, and I get about 18 mpg on the open road @ 65 mph and 15-16 mpg in town. 13 mpg is too low on the highway i think. I never have seen 21 plus mpg on my truck. How many miles? Proper maintenance? Chunk.
  11. Jun 17, 2018 at 9:27 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd be looking at O2 sensors and doing plugs, air filter, pcv, and cleaning the MAF.
  12. Jun 17, 2018 at 9:42 AM
    Professional Hand Model
    Hand Protectors
    This is about what I’m getting as far as MPG’s (16/18) even with 285/75/r16’s LTX Michelins. My mechanic said a bad o2 sensor will decrease mpg by 1 mile. Also, who knows what your maintenance looks like? Spark plugs, MAF clean, throttle body clean, air filter, wrong oil viscosity etc? Try unplugging your battery for a reset and do a fresh gas fill up with some STP gold label fuel additive to start cleaning your fuel injectors (easy beginning). Then tick all the other boxes everyone else mentioned above.
    mudslinger79 and Casper421 like this.
  13. Jun 17, 2018 at 10:29 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I don't think my 03 would ever get 24.5mpg. Even going down hill with the wind.
  14. Jun 19, 2018 at 6:35 PM
    The tundy
    2001 tundra limited
    Thanks for the replies everyone. the truck has just under 218,000 miles on it she runs like new I did the spark plugs about 5k miles ago. I change the oil every 5k miles too with the recommended oil every time as for the Air filter, it looks good I haven’t looked into the maf or throttle body yet I’m hoping I can get around to that sometime soon and as for the o2 sennsors wouldn’t the check engine light come on?
  15. Jun 19, 2018 at 6:40 PM
    The tundy
    2001 tundra limited
    Haha I was in disbelief when I saw 24.5 at first too. I have heard of a few guys getting around the same but not too often. Everyone I tell seems to be amazed that a 17 year old v8 pickup truck could do that.
  16. Jun 19, 2018 at 6:47 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    O2 sensors won't necessarily throw a light. They can get slow to respond but still be within an "acceptable" range. Basically keeping it running rich enough to burn through fuel but still within what might be normal for a cold start.
    Sunnier and landphil like this.
  17. Jul 8, 2018 at 3:55 PM
    trash.panda
    trash.panda New Member
    2005 Ext cab 6spd
    Any luck on solving the mileage issue?
  18. Jul 8, 2018 at 11:25 PM
    The tundy
    2001 tundra limited
    Basically it seems like at 65 mph the fuel burn isn’t bad I’d even say it’s pretty good but anything above 65 and it’s burning way more gas than it used to. I did get to rev it out for the first time in a while and that did seem to help a little but not enough to solve the problem
  19. Jul 9, 2018 at 4:51 AM
    I replaced spark plugs on a commuter car, the plugs were supposed to be pre-gapped so I didn’t check. About 4-6k miles later the car was doing horrible on fuel economy and eventually wouldn’t start.
    Come to find out the plugs were not gapped properly. Fixed gapping issue, used same plugs for another 60k miles.
    If you checked them, then something else is going on.
    Getting close to changing timing belt?
    Wheel bearings good? (Check with thermal gun after a good long drive)
    To drop that kind of mileage all of a sudden, something significant is happening.
  20. Jul 9, 2018 at 5:24 AM
    trash.panda
    2005 Ext cab 6spd
    Do you have one of the bluetooth OBDII interfaces? It would be interesting to see what your Long Term Fuel Trim (LTFT) and Short Term Fuel Trim (STFT) numbers are per bank of cylinders. That fuel is going somewhere... and I'd start with a peek at the fuel trim numbers.
  21. Oct 3, 2018 at 8:54 PM
    johnyz
    johnyz New Member
    john
  22. Oct 3, 2018 at 8:59 PM
    johnyz
    johnyz New Member
    john
    The rpm tells the story if you in the sixed gear you should run it under 2000rpm 2500 way too high rpm.Make sure you in the sixed gear.Also if you haven't replaced your differential oil at about and every 30000 miles.your mpg will drops.
  23. Oct 4, 2018 at 6:02 AM
    The tundy
    2001 tundra limited
    The truck is a first gen with the 4 speed and the 3.92 rear end 2500 at that speed is normal. The engine is back to normal fuel consumption though the injectors were a little clogged. I should change the differential fluid though hopefully get it up even higher.
  24. Oct 4, 2018 at 6:26 AM
    Hand Protectors
    Did you remove and have your injectors cleaned?
  25. Oct 4, 2018 at 7:06 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Never seen higher than 18mpg in my 06 with 265/70r16 Goodyear Wrangler ATs
  26. Oct 4, 2018 at 7:49 AM
    Hand Protectors
    Thats the same here highway driving with the 02’ on 285/75/r16.
    City is more like 10-12 mpg.
  27. Oct 4, 2018 at 8:17 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Good to know. That's what size I plan to do after I lift it. Not sure if I want ATs or MTs yet.
    Bow that I think about it I've yet to go more than 30nmiles or so at a time in my truck since I bought it a about 5 weeks ago
  28. Oct 4, 2018 at 8:56 AM
    Hand Protectors
    Tread and rolling resistance of tires can make a tremendous difference in MPG. If you research many of the tire companies different options of tires within each brand, then you it will make sense.
    Sounds like you recently changed to all terrains? And now have worse mileage?
