'00 Tundra Hard Shift 2nd to 3rd
Discussion in '1st Gen Tundras (2000-2006)' started by Jimbobber10, Jan 25, 2021.
  1. Jan 25, 2021 at 6:51 PM
    Jimbobber10
    Jimbobber10 [OP] New Member
    2000 V8 4.7L
    V4.7. When giving it about 3/4 throttle from stop, shifts fine into 2nd but. At about 40mph @ about 4K rpm, it 'jerks' in to 3rd gear pretty violently.
    Anyone have/ remedy ?
  2. Jan 25, 2021 at 7:43 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Check your tranny fluid level. It may be too low. I had a similar issue so I switched over to Mobil 1 synthetic for the tranny fluid and it helped. Some have tried AutoRx with good results.
  3. Jan 26, 2021 at 7:03 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    My 2015 had the same issue. It turned out to be a tranny issue. Toyota authorized a replacement. Check with your dealer and you will have to be able to reenact the issue. It took 2 trips for me. The service manager rode with me on the second trip. He heard it, felt it and drove it to experience the issue.
  4. Jan 26, 2021 at 7:09 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Pretty sure they aren't going to warranty a 20 year old transmission.:spending:
    @Jack McCarthy has the right initial step. Check the fluid level first, should be up to temp and idling in park to check it.
  5. Jan 26, 2021 at 7:10 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Had a similar issue shifting 1st to 2nd. Had to do with the transmission valve body. Could be easy fix if it’s only the valve spring that needs replacing. That was my experience
    Should also mention, the transmission shop told me to first try Lucas Transmission fix additive because it could simply be a dirty valve that’s sticking. Bottle costs like $13 at auto zone.
    KingsAustin likes this.
  6. Jan 26, 2021 at 7:11 AM
    KingsAustin
    Morgan County, AL
    Into my 3rd cup of Joe. I didn't see that part. Thanks for pointing it out.
    tvpierce, Festerw[QUOTED] and N84434 like this.
  7. Jan 26, 2021 at 9:50 AM
    Jimbobber10
    2000 V8 4.7L
    Thanks guys. It's not an intermittent issue, happens always, and I want to fix it before it does damage. I'll look in to cleaners, but I had the transmission checked and changed fluids 3 years ago by the stealership.
  8. Jan 26, 2021 at 1:26 PM
    Professional Hand Model
    Hand Protectors
    Bring your truck engine up to Operating Temp by driving around a bit. With the engine ON, check the transmission dip stick. Should read right at the top tick/hash mark. This is a cheap and easy way to confirm you have the proper level.
    Goofy Service Work done 3 years ago may not have filled it proper as Toyota ‘spec’ states 2.1qts (as a drain and fill) and in reality it is more like 4qts. Low fluid will make your shift hard in 2-3rd.
    Use DEX/Merc and add some if its low. Add down the dip stick.
  9. Jan 26, 2021 at 8:34 PM
    Voss
    Valod
    2003 AC TRD 4x4
    Just because it’s you, I’m most likely going to drain and refill my transmission based on how much fluid you said is needed. Lol
  10. Jan 27, 2021 at 3:51 AM
    Hand Protectors
    Sounds good. I’ve only done a few drain and fills and the first one was a learning experience. Check Dip Stick when HOT before the drain and fill to make sure your level is proper. If its low, then you know you’ll need to add a little more on the refill part of the job.
    My first job was 1 quart low from prior Goofy Garage. The transmission shifts are so much better with the level at the top hash or even a little tick higher.
  11. Feb 19, 2021 at 8:08 PM
    Jimbobber10
    2000 V8 4.7L
    Trans fluid is full. Anything else I can check in to? Anyone think a dirty fuel filter would cause this? I don't think they replaced when they drained/filled the trans fluid 3 years ago. Again, it's always done this since I got it and it hasn't gotten worse.
  12. Feb 19, 2021 at 8:32 PM
    Jack McCarthy
    Bill
    North of Boston
    One way I’ve found to soften a harder shift if it’s holding rpms longer than it should before shifting is to briefly let off the gas slightly in anticipation of when the shift should be and then go back to where you were with the gas pedal. This will trick the transmission into shifting when you want it to do so.
    If you’re due for another tranny fluid change you could put in the AutoRx and run it for a 1000 miles before changing the fluid. I haven’t tried it but I’ve heard from others that it worked for them.
  13. Feb 19, 2021 at 9:59 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the a340 in both my tacomas had a harder shift between 2nd and 3rd.. i just ignored it. never an issue.
    the 02 even has a whine in first gear. but the 01 never did..
  14. Feb 20, 2021 at 7:52 AM
    Don't think it's a dirty fuel filter. It's likely an internal valve body problem. Aggressive cleaning in an old trans is not a great idea, unless you're gonna take the trans out and disassemble it. Gentle cleaning may help, or you may just have some worn out components in the trans that will never come back to life. Gentle cleaning would be a drain and refill, maybe even using an additive like the lucas oil. I've used it in mine and it's helped with my 1-2 shift clunk. Also, I partied with one of the executives from Lucas in Cancun last year at our resort. Real nice guy, their products must be really good (Very scientific assessment of the product).
