00-20 Oil?
Discussion in 'Towing & Hauling' started by Wesley1960, May 1, 2018.
  1. May 1, 2018 at 3:47 AM
    Wesley1960
    Wesley1960 [OP] New Member
    Roman
    2018 Tundra Limited
    On my 2018 Tundra Limited 5.6L the manual says use 00-20oil use a heavier oil when towing. I tow a boat or camper any suggestions on oil weights?
  2. May 10, 2018 at 10:53 AM
    Wintyfresh
    Wintyfresh New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    Depends on where you're located and how much your boat and camper weigh, but a 5w30 or 5w40 would be my recommendation.
  3. May 10, 2018 at 11:03 AM
    15whtrd
    15whtrd Mr. Blonde
    No!
    Read the manual it says 0–20. And if you tow 5–20. But then it says if you do run 5-20 you need to switch it back to 0-20 on the next oil change. Something along those lines. I just run 0-20 and call it a day.
  4. May 10, 2018 at 11:10 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    I towed a 6000 lb trailer across the country and the 0-20 mobile1 oil worked perfect. Had it analyzed after and everything was fine.
    15whtrd and GNTundra like this.
  5. May 10, 2018 at 11:44 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I run 5W- 20 only. The 5 is the viscosity upon startup, so just slightly thicker upon startup than the 0. Still I have considered running 5w-30 as 20 weight just sounds too thin to me. However there have been many Tundras with high miles running that oil, so who knows...
  6. May 10, 2018 at 12:00 PM
    Wintyfresh
    Ramona, CA
    0w20 is spec'd because of CAFE (Corporate Average Fuel Economy) standards, in addition to the slight mileage increase it's well suited to urban driving. I don't believe running 0w20 while towing is an automatic death sentence for your motor (as ChrisTRDPro's UOA shows), but there is a strong argument for the protection provided by a higher viscosity oil if you are towing heavy in hot environments.
