+0 offset wheels with wheel spacers?
Discussion in 'Wheels & Tires' started by Jman245, Jun 4, 2019.
  1. Jun 4, 2019 at 12:31 PM
    Jman245
    Jman245 [OP] Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    I couldn't find any info on this set up. I have 17x8.5 wheels with +0 offset with 285/75 tires and a 3' lift with bmc done. I want more poke with my set up without buying new wheels. Thinking of doing spidertrax or Bora spacers. Not sure on the size tho... thanks, please post pix of you have this set up! Btw, I'm eventually gonna do 37s after I get some uca's
  2. Jun 4, 2019 at 12:33 PM
    15whtrd
    15whtrd Mr. Blonde
    Be prepared to do some trimming! What size tires are you going to go with?
    Jman245[OP] likes this.
  3. Jun 4, 2019 at 12:34 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I'm on 285/75 currently but will go to 35s or 37s after I get uca's
    15whtrd[QUOTED] likes this.
  4. Jun 4, 2019 at 12:41 PM
    15whtrd
    15whtrd Mr. Blonde
    Just a suggestion, get your lift installed with the tire size you plan on going with. See how much rub you’re going to have with that size. Then imagine it even worse with spacers. That is going to be a lot of leverage on your wheel hubs as well. Not trying to shit on your idea. But the further out you go, the larger the radius of the outside edge on the tire rubbing into your bumper and body mount.
  5. Jun 4, 2019 at 12:43 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I already have the set up installed minus the uca. I'm just wondering if I can do this once I have uca's on. I dont want to buy spacers and not be able to use them
  6. Jun 4, 2019 at 12:46 PM
    15whtrd
    15whtrd Mr. Blonde
    If you’re worried about the tires rubbing the UCA. It shouldn’t at all. If you add the spacers it will be even further from it. I doubt the UCA will be any problem whatsoever. More of the spacer and clearance issues of everything else. Hopefully someone can chime in that has done this exact set up you’re talking about.
    Trooper2 and Jman245[QUOTED][OP] like this.
  7. Jun 4, 2019 at 12:51 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Not concerned about it rubbing the uca's, more so with the bumper or body mount area even with my bmc already done.
  8. Jun 4, 2019 at 1:00 PM
    MSbowhunter48
    MSbowhunter48 New Member
    2011 White Tundra Rock Warrior Edition
    Fat Bob’s 3/1 Leveling kit Rock Warrior Wheels 317/70R17 Cooper AT3 XLT
    1” spacer would put you around -25 offset, 1.25” spacer would put you around -32 I believe, and 1.5” should put you close to -40 offset if Im thinking correct. I would try looking up folks with that much negative offset and see what it took for them to clear the size tires they are running. Not much help I know, but it’s a start.
    Jman245[OP] and 15whtrd like this.
  9. Jun 4, 2019 at 1:27 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    I have 0mm offset and Spidertrax, 17x8.5 and 35 x12.50:
    I have BMC, and I started rubbing with the 35's on the BMC
    Had to trim front bumper too.
  10. Jun 4, 2019 at 1:30 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Your rig looks great! Do you have uca's? And what size spacers did you go with?
  11. Jun 4, 2019 at 3:49 PM
    itsdchz
    Clovis, CA
    Spidertrax, i think only offers 1.25" for our vehicle. Thats what I have.
    I have ICON billet UCA's, but honestly with that offset and BS, along with the spacer, there is a crapton of room.
    Jman245[QUOTED][OP] likes this.
  12. Jun 10, 2019 at 12:08 PM
    itsdchz
    Clovis, CA
    FYI
    Changing my flares to painted, snapped these pics when removed so you can see the 0mm offset, 4.25” BS 17x8.5 Spidertraxx 1.25” -without the flares:
  13. Jun 10, 2019 at 12:11 PM
    TheBeast The Beach
    oh wow, that sticks out quite a lot. is it because of the 0mm offset or the added spidertraxx ?
  14. Jun 10, 2019 at 12:30 PM
    itsdchz
    Clovis, CA
    Looks way more compatible with flares due to the offset.
    Jman245[OP] and TheBeast[QUOTED] like this.
  15. Jun 10, 2019 at 12:45 PM
    TheBeast The Beach
    yes it works with your flares but for someone without, be ready to repaint those fenders :)
    15whtrd likes this.
  16. Jun 10, 2019 at 2:26 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    That's because of the spacers
  17. Jun 10, 2019 at 2:29 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    Are you using oem uca's? Im thinking I'll need to change those out and add bumper spacers so that I won't have to trim the bumper much more, fingers crossed.
  18. Jun 10, 2019 at 2:44 PM
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    lovely
  19. Jun 10, 2019 at 2:53 PM
    I have Spidertrax sitting in the tool box that are practically brand new and I cant use them any more. They were used for a month before I bought new wheels.
