+0 Offset Poke w/ Flares Help
Discussion in '2nd Gen Tundras (2007-2013)' started by PayItOff428, May 20, 2022.
  1. May 20, 2022 at 6:06 AM
    PayItOff428
    PayItOff428 [OP] New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Hey Gang,
    I found a set of 17X8.5 0 offset Raceline Aero’s in machined finish I want to purchase but I am worried about the amount of poke I will get by choosing these. I have fender flares and will run 35’s with this rim. Does anyone have a photo of 0 offset wheels with fender flares your willing to share. My truck below with photo of wheel I am considering. Truck has a 6” ProComp lift. Going for that classic 80’s ish look.
  2. May 20, 2022 at 6:52 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. May 20, 2022 at 7:01 AM
    I have a 0 offset with 285/70's and my tires are flush with the outer edge of the Bushwacker flares.
    tundratoofun and Booney like this.
  4. May 20, 2022 at 7:03 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    You could just do the math..
    What is your current offset? Offset is measured in MM. If your current offset is, for example, +12 (~1/2"), then you can just use a ruler or tape to see where the new wheels would sit.. Pretty straightforward.
  5. May 20, 2022 at 7:11 AM
    PayItOff428
    Jake
    Thank you all!
  6. May 20, 2022 at 8:38 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Here is what 35's with +12mm offset looks like on a truck with flares. No poke. 0 offset will be out another 1/2".
    wyoboypt likes this.
  7. May 20, 2022 at 8:58 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I had the same concern but I looked at @Tundra234 truck and liked the result. I followed his lead. I have 0 offset with 315/70R17 tires and fender flares. The tire tread is pretty much flush.
  8. May 20, 2022 at 12:57 PM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    O offset is perfect to me. No fender flairs and its just about the right amount before looking meat head lol.
    tundratoofun likes this.
  9. May 20, 2022 at 2:41 PM
    PayItOff428
    Jake
    So I’ve concluded that +0 and the associated poke looks different depending on the width of the rim. Is that a correct statement?
  10. May 20, 2022 at 3:25 PM
    Booney
    Booney New Member
    Yep. Width of tire will make a difference. Here are a couple of offset calculators. They will show you the difference between a stock set up and the custom tire width and offset rim.
  11. May 21, 2022 at 9:08 AM
    Shuffler
    Shuffler New Member
    NW Montana
    2011 CrewMax 4WD
    Weird ... you got less poke with more offset than I had with +18 and 295s (Method Roost 20x9) ... which stuck out about 1.25"
  12. May 21, 2022 at 9:29 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's +1 on 18x9 wheels
  13. May 21, 2022 at 11:42 AM
    Booney
    Booney New Member
    My tire side wall and the fender flare sticks out about 1.75 from the stock fender. The outer side wall sits out a little more than 3 inches from the inside of the wheel well than stock the stock tire did. The top one is my set up.
    Here is your set up:
  14. Jun 18, 2022 at 4:20 AM
    Str8himalaya
    Str8himalaya Here to learn!
    Nick
    Ohio
    2017 Tundra SR5 TRD Off Road
    7” Stage I Pro Comp Lift
    I’m actually curious about suggestions as well. I seem to be getting little paint nicks on the bedside and doors, think it maybe because of my offset (bought the truck like it is so not sure what the offset is on the wheels and haven’t measured). With the pictures provided, should I go with some flairs?
  15. Jun 18, 2022 at 5:13 AM
    Look on the back side of the wheel. You will see some numbers stamped. Look for one that says ET. That will be your offset.
  16. Jun 18, 2022 at 6:52 AM
    Booney
    Booney New Member
    I would suggest some fender flares.
    Neo258 and Tundra234 like this.
