+0 offset method RW with 285/70/17 tires?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by DMB4x4, Feb 24, 2019.
  1. Feb 24, 2019 at 10:54 AM
    DMB4x4
    DMB4x4 [OP] New Member
    2014 Tundra SR5 CM 4x4
    I have a 2014 CM 4x4, and I’m Looking to put 17” methods on with 285/70/17 tires. Anybody have this setup? Any rubbing or figment issues? Brake calipers for with it being +0 offset?
    I have Bilstein 5100 level set @ 1.9”
    Thanks.
  2. Mar 4, 2019 at 11:35 AM
    BajaTurd
    BajaTurd Burrito Champion
    Aj
    San Diego
    19 4x max
    Camburg uppers Kings Deavers
    If its the new trail series, I called method and they said it clears everything fine as far as brakes go, so best bet would be to call method and tell them what wheel you want to run. With that tire you should'nt have a problem. interested how it turns out if you go thru with it post pics!
