0 offset…modifications required?
Discussion in '3rd Gen Tundras (2022+)' started by EveryDayEnthusiast, Nov 21, 2023.
  1. Nov 21, 2023 at 9:01 PM
    EveryDayEnthusiast
    EveryDayEnthusiast [OP] New Member
    Thinking about getting some 17x8.5 0 offset race relations. Westcott says they recommend their relocation kit to fit them. I’ve seen videos where people take off a safety bracket to pin back the rear fender liner, but see a lot of guys running 0 offsets. Is this safe? Any personal experience? Hoping to run 35x12.5r17
    edit. Ordered the 18” with the +12 offset only to switch to the 17 +0. The weight difference was so much higher I decided to go 17.
    appreciate all the comments
  2. Nov 22, 2023 at 6:39 AM
    Tom
    Tom New Member
    Your wheels are gonna stick out 3” on each side. If you have a single door garage it’s gonna be a bitcha getting in.
    Cheeko likes this.
  3. Nov 22, 2023 at 7:27 AM
    Cheeko
    Cheeko New Member
    23 Plat
    I run 0 offset 18s on 35s. I unscrewed a couple brackets and pinned back the felt. I didn't cut off the safety thingy that sticks out so the tire on the passenger side rubs a little when I cut the wheel in reverse. I'm happy with it.
  4. Nov 22, 2023 at 7:31 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The wheels and tires will stick out so a suggestion would be to get some flares to protect the sides of your truck and keep the mirrors from getting smashed by flying debris.
    I have a slightly smaller size tire and a lesser offset (+15) and I have some rubbing. I took off my mud flaps too. My favorite wheels are "0" offset and but I didn't want to deal with major mods to the truck.
  5. Nov 22, 2023 at 7:37 AM
    Cheeko
    Cheeko New Member
    23 Plat
    This is very true... The sides of my truck gets really dirty especially when it rains! Also picked up some tar from roads work that I need to clean off at some point.
  6. Nov 22, 2023 at 7:42 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    probably because they're having a big sale right now
    if only they offered their wheels with an offset for normal sized tundras
    ryanwgregg[QUOTED] likes this.
  7. Nov 22, 2023 at 7:47 AM
    b6graham
    b6graham New Member
    because black friday
    as much as i would really like a set of RR7-H personally. i can't do a 0 offset. don't like the poke and everything that comes with it. now if they had a +25 i'd be all over it
    BMP likes this.
  8. Nov 22, 2023 at 7:54 AM
    Cheeko
    Cheeko New Member
    23 Plat
    I like what I like is basically the why. I don't mind a dirty truck, I like the poke.
    az 3rdGen likes this.
  9. Nov 22, 2023 at 8:44 AM
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    Hell yeah! If everyone liked the same thing, there wouldn't be threads with thousands of responses of people customizing their trucks. I, for example, am planning on getting 22x10 -18mm on a 35x12.5 in February. I like what I like!
    Cheeko[QUOTED] likes this.
  10. Nov 22, 2023 at 8:49 AM
    b6graham
    b6graham New Member
    are you truck confused? you sure you have a Tundra and not a Ford SuperDuty with that wheel and tire selection? :monocle::monocle::monocle: /s
    ryanwgregg likes this.
  11. Nov 22, 2023 at 8:58 AM
    az 3rdGen
    Arizona
    Cheeko likes this.
  12. Nov 25, 2023 at 6:21 AM
    BMP
    BMP New Member
    2023 Tundra SR5 SX MGM CM 4X4
    Extra $$$ to spend and it's "on sale".
    Brad
  13. Nov 25, 2023 at 7:47 AM
    EveryDayEnthusiast
    <20 lbs forged wheels for 350 bucks a piece is a great deal. Pretty practical if you don’t want to spend 800 a piece on Rays to not be 90+ lbs a corner.
