• on the climate control knob?
Discussion in '2nd Gen Tundras (2007-2013)' started by 1rooster, Feb 20, 2020.
  1. Feb 20, 2020 at 9:12 AM
    1rooster
    1rooster [OP] New Member
    Tony
    2007 crewmax
    Anyone know what the dot is suppose to represent between air flow settings?6C85314C-D292-49A6-8CFD-37C8C7E13D43.jpg
    Fiesta346 likes this.
  2. Feb 20, 2020 at 9:16 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    Been wondering the same is the knob supposed to be lined up with the dot or the arrow/person icon?
  3. Feb 20, 2020 at 9:22 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s a mixture between the two.If you have it on the dot between face and feet and face it’s going to do both but favor the face a little more.
  4. Feb 20, 2020 at 9:26 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I go to the caricature out of habit. 2 clicks for every change. Never really paid attention to the middle.
    TRD-tv and 1rooster[OP] like this.
  5. Feb 20, 2020 at 9:56 AM
    1rooster
    Tony
    2007 crewmax
    Awesome! Just tried it out a little bit ago and you are correct. I always thought it has something to do with the flow to the rear vents!
    15whtrd[QUOTED] likes this.
  6. Feb 20, 2020 at 9:56 AM
    1rooster
    Tony
    2007 crewmax
    Also does anyone know a way to keep the recirculate on and not shut off every three minutes?
    kenomouth64 likes this.
  7. Feb 20, 2020 at 10:00 AM
    15whtrd
    15whtrd Mr. Blonde
    Unless they can do that through programming, none that I’m aware of. I think it will stay on recirculate depending on the temperature outside the vehicle. But I can’t remember if it was below or above a certain point that kept it on.
  8. Feb 20, 2020 at 10:00 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Hold the recirculate button down for over 10 seconds (I count out about 15 seconds to be sure) and it'll stay on until you change to defrost. Remote start also opens it.
    D4x4TRD, Sunnier, 15whtrd and 2 others like this.
  9. Feb 20, 2020 at 10:02 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If that can't be made to happen, it can also be changed via Techstream.
    15whtrd likes this.
  10. Feb 20, 2020 at 10:06 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Thats the "non-binary" position. Its not one or the other.
    9am53, Sunnier, focal and 1 other person like this.
  11. Feb 20, 2020 at 10:06 AM
    1rooster
    Tony
    2007 crewmax
    Interesting. I’ll have to give it a try. All I know is it is very aggravating to keep having to hit the darn button.
  12. Feb 20, 2020 at 10:08 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I had this same problem on my FJ; Recirculate would only stay on if I had it set to MAX AC; otherwise it would turn off after a few minutes.
    kenomouth64 and 15whtrd like this.
  13. Feb 20, 2020 at 10:08 AM
    15whtrd
    15whtrd Mr. Blonde
    Is that a auto climate control only feature or does it work with the manual controls as well?
    Randy Morton[QUOTED] likes this.
  14. Feb 20, 2020 at 10:12 AM
    Randy Morton
    Randy
    I don't know about the auto climate control, but it works on my 2nd gen with manual controls.
    15whtrd[QUOTED] and 1rooster[OP] like this.
  15. Feb 20, 2020 at 10:14 AM
    1rooster
    Tony
    2007 crewmax
    I don’t recall my old fj doing that. D769934D-0B8E-4DB7-A326-4181A3F7F410.jpg
  16. Feb 20, 2020 at 10:15 AM
    15whtrd
    15whtrd Mr. Blonde
    I’ll have to try it on my 2.5
    Sunnier likes this.
  17. Feb 20, 2020 at 10:29 AM
    Ericsopa
    Ericsopa Old man and the sea
    With climate control everything is automatic unless you turn off the "auto" button. Then you can set it any way you want. But recirc is on each time you start the truck if not it auto mode. Not sure if it stays on, because I always turn it off after starting the truck in order to have fresh air.
    15whtrd[QUOTED] and Wynnded like this.
  18. Feb 20, 2020 at 12:30 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  19. Mar 3, 2020 at 9:06 AM
    Randy Morton
    Randy
    Did you get recirculate to stay on?
  20. Mar 3, 2020 at 9:17 AM
    BENWALES
    BENWALES New Member
    Ben
    2020 Tundra White SR5
    My 08 drove me nuts with that but it was the opposite way, it would switch from fresh air to recirculate all by itself. I evacuated and recharged the AC system thinking the evaporator was freezing up due to low freon (wrong). I swapped in a new blower motor thinking it was not moving enough air across the evaporator causing a freeze up (wrong). I call my buddy who's a Master Toyota tech and he lol'd "They all do it, no there is nothing wrong, R.T.F.M. and stop calling me for your neurotic shit." He's a great friend.
  21. Mar 3, 2020 at 10:14 AM
    1rooster
    Tony
    2007 crewmax
    Hold the button down for 5-6 seconds seems to work for me.
