‘14 Platinum Family Truckster
Discussion in 'Sequoia Builds' started by Bitzbp, Dec 30, 2022.
  1. Dec 30, 2022 at 5:56 PM
    Bitzbp
    Bitzbp [OP] New Member
    So after a long time following everyone’s builds quietly, I decided to join in, now that I have something to add to the forum. I appreciate following along on everyone’s builds and seeing them evolve.
    Quickly a little about myself, I worked as a tech in the automotive field growing up and then I worked for a Toyota dealer in the service department for 11 years progressing to a service manager when I eventually left the automotive field. I got to see the 2nd gen sequoia be released in showroom floors where, at the time I thought it was unnecessarily large as I was young and single and enjoyed driving my sports cars. Now with 3 kids, we outgrew our RAV4, Highlanders (had 2 of them), and still have the wife’s Sienna. I finally realized how perfect the Sequoia is. I always appreciated how reliable this generation sequoia was and early in ‘22 I finally picked up a ‘14 Platinum!! Been loving it ever since.
    Current mods:
    Method wheels w\ Ridge Grapplers
    OEM sport grill (comes painted)
    Painted handles and mirror caps
    Blacked out inside of headlights (aftermarket)
    Tinted tail lights ( may change this as I'm not totally loving them)
    TRD PRO suspension (not installed)
    Westcott Designs lift collar ( not installed)
    Tandem air bag spacer (still waiting)
    LED bulbs everywhere (need this as my night vision is terrible)
    Blackout badges (not installed)
    Misc things I forget
    Here is a picture of it stock one of the first days I had it:
    Here are a coup!e pics of how it sits today
    I still have a bunch of parts to install including the TRD Pro suspension and TRD sway bar and Im waiting on the Tandem air bag spacer to lift the truck but retain factory air bags.
    Thundra27, Kwe1982, NoRcptn and 10 others like this.
  2. Dec 31, 2022 at 4:39 AM
    farnsrocket
    farnsrocket New Member
  3. Dec 31, 2022 at 4:40 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    :drool::drool::drool::drool:
    Love me some modded sequoias!
  4. Dec 31, 2022 at 10:53 AM
    Bitzbp
    Love your truck! Your truck is an inspiration for me during my build. For now I only got the rear TRD bar but may just grab the front. I read the front bar is the same size but solid so it should make a difference. I pushed the limit with tires and got 305/70/17 Ridge Grapplers. I removed the front mud flaps so far but it will rub the body mount when turned too much. I’m gonna try lifting it and see how it is, but it’s totally driveable and not sure I want to commit to the bmc. I have a couple other things on order so I’ll update as I install.
    farnsrocket[QUOTED] likes this.
  5. Dec 31, 2022 at 11:29 AM
    farnsrocket
    Thanks man! :drunk:
    Yeah front bar is an improvement.
    There's not much difference in our tire setups......are your rims +18 offset too? If they are 0 that could be the difference. Mine are +18 and I had no issues before I lifted it.
  6. Dec 31, 2022 at 1:48 PM
    Bitzbp
    Yes they are 0 offset but they are also 17X8.5 which I think the 18’s are 18X9 +18. So there is a difference there as well
  7. Dec 31, 2022 at 2:18 PM
    farnsrocket
    Yeah with 0 offset yours stick out 1.3” farther minus 1/4” give or take for your narrower rims.
  8. Jan 22, 2023 at 7:00 PM
    Bitzbp
    So I've done a couple little things while I wait for better weather to do suspension
    I continued getting rid of the chrome. I ordered black "platinum" badges which seemed like an exact match for the OEM badges, and then I tried plastidip on the tail gate garnish and "5.7" badge. Came out pretty good and I probably will live with it for a while as opposed to ordering the overpriced OEM replacement.
    I changed the reverse and license plate bulbs to LED for a cleaner\brighter look.
    omgboost and farnsrocket like this.
  9. Jan 23, 2023 at 4:18 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Nice work!
  10. Jan 24, 2023 at 5:33 AM
    S. Equoia
    S. Equoia New Member
    Ontario, Canada
    2015 Sequoia
    Looks good! Well done on the plastidip.
  11. Jan 29, 2023 at 5:42 PM
    Bitzbp
    A couple small updates. I didn't want to buy new OEM tire sensors or move them from the factory wheels but I hate seeing the tire light on the dash. Cue the aftermarket tire sensors and display:
    The display fits in the location of a factory switch so I decided to move the "Tow\haul" button over to a blank spot near the rear window switch and mounted the tire display in its place. Looks pretty good and seems to function well. I like that I now know each tires pressure and location on the truck so if there is an issue its easier to identify.
    I also bypassed the factory TPMS system, the correct way (no cutting wires!). So there is no light on the dash!
    Lastly I replaced the noisy blower motor that had been annoying me since I purchased the truck a year ago. I debated going OEM, but honestly, working at Toyota this was a common problem so I figured to save some money and just buy one from RockAuto. So far so good and much quieter then the old one, but if I'm honest I still feel like its noisier then it should be but its been a while since I've heard a good OEM blower.
  12. Jan 29, 2023 at 7:08 PM
    farnsrocket
    That’s a cool tire sensor set up, who makes it and how does it work?
  13. Jan 29, 2023 at 8:43 PM
    Bitzbp
    I found it on Amazon, the sensors screw on and replace the valve stem caps. They are a little larger then I would like but they work well and beat having to break down the tire\wheel to install internal sensors and find someone good enough to balance heavy tires.
    https://www.amazon.com/HUAHAT-HuaHa...e2a-a37b-4d1b7571fa22&pd_rd_i=B071Z8BT46&th=1
  14. Jan 29, 2023 at 8:51 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Where did you get the platinum badges? Nice truck! Thanks.
  15. Jan 30, 2023 at 5:12 AM
    Bitzbp
    i got them from Ebay. Here is the link from the seller: Note, badges were great quality and seem OEM like but be careful, this is just for “one” badge, originally I thought it included both and had to go back to order another. Although they look/fit perfect, I’m not sure I would have jumped to buy them if I knew it would be $40 for both. I may have shopped around a bit more
    https://www.ebay.com/itm/194487990973
    omgboost likes this.
  16. Jan 30, 2023 at 3:49 PM
    e30cabrio
    TPMS mod is cool!
  17. Jan 31, 2023 at 2:41 AM
    Beau
    Beau
    Thanks!
  18. Feb 4, 2023 at 2:41 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Is that item specific to Toyota for the knockout switch plate? I didn’t see it for toyota, only nissan and honda.
  19. Feb 7, 2023 at 8:03 PM
    Bitzbp
    So I went and double checked, the one I ordered was definitely for Toyota, not the Nissan one, but for some reason they aren’t offering that one as an option now….
    BrandonL812[QUOTED] likes this.
  20. Feb 27, 2023 at 11:55 PM
    SBLongview
    SBLongview New Member
    byron
    '13 Sequoia Platinum
    Stock city…researching the build!
    Cool build. Enjoying watching this come together. I have a ‘13 that I’m building up right now thanks to all the inspo on the threads. I’ll post mine soon.
    In the meantime, any thoughts on tail lights? Any plans to do anything there? Doesn’t look like many options.
  21. Mar 9, 2023 at 10:54 AM
    Bitzbp
    I would love if someone produced some tail light options. I did read there is a company that has them in the works but we will see. For the time being I smoked them and added LED reverse lights.
  22. Mar 9, 2023 at 11:35 AM
    Bitzbp
    So I added a few more things to the truck. I really want to do a full Baja style front bumper at some point but for now I installed a bull bar with light bar up front. I like how close to the bumper it can be positioned. Note* you will lose radar cruise with this bad (which I knew in advance, but barely used). I also added 2 recovery points where the tow hooks were.
    I also added an inexpensive roof basket as we were going away and I wanted more storage space. I also bought a waterproof sac for the roof to put stuff in, in case in rained (which of course it did on our trip) worked great! I have to say I was really happy that at speeds 75mph and below I did not even hear the roof rack or tires. The hacked exhaust is another story…. Previous owner had an aftermarket muffler welded in which sounds great at idle and lower speeds but drones terribly at 70-75mph. I even tried to order the factory exhaust but it is on an insane back order with no production date.
    A couple other small things I need to install but I will find some time and try to post them up. So far this is the best truck I’ve ever had and I’m thoroughly enjoying taking long drives with the family. Can’t wait to do some light off roading in the spring.
