No lift help needed
Discussion in 'Suspension' started by Toyfan2, Feb 2, 2019.
  1. Feb 2, 2019 at 7:31 AM
    Toyfan2
    Toyfan2 [OP] New Member
    FL
    My 09 Tundra with 192,000 miles drives like a boat, shocks are shot. It's a regular street ride with no lift and I want to order from Rock A. All there shocks say without TRD offroad. I see that I have a TRD air box, but there are no badges identifying offroad or not.
    How can I tell what I have so I don't order the wrong part. This site is great, I now know, I do not have STRUTS.
    T-Rex266 and Black Wolf like this.
  2. Feb 2, 2019 at 7:38 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    15whtrd likes this.
  3. Feb 2, 2019 at 7:49 AM
    15whtrd
    15whtrd Mr. Blonde
    If it were me and I wanted to remain close to stock with little to no lift.. I’d go Bilstein 5100 set to the lowest setting.
  4. Feb 2, 2019 at 7:50 AM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    This +1
  5. Feb 2, 2019 at 7:53 AM
    Toyfan2
    FL
    Thanks Trooper2, I entered my VIN and found that it's just a plain Jane SR5. I think your right, someone might of added the TRD airbox.
    Rica25, kparrow and Trooper2 like this.
  6. Feb 2, 2019 at 7:59 AM
    +2
  7. Feb 2, 2019 at 8:16 AM
    TRD or not, same front end so replace as u see fit.
  8. Feb 2, 2019 at 8:17 AM
    Trooper2
    JR
    The dealership can also verify by vin what you had stock, if going that route.
  9. Feb 2, 2019 at 8:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Like T-Rex said, the shocks will be the same despite what their disclaimer says.
  10. Feb 2, 2019 at 9:01 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    2008 Tundra DC 4x4 5.7l V8 Blue Streak Metallic
    Goodyear UltraTerrain AT 275/70/r18, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, DECKED, and lots more!
    +3, Bilstein 5100’s. Set on lowest setting in front if you want stock, middle if you want it leveled. I just priced these the other day. 4 shocks, new rear shock bushings, and new top hats for both sides of the front was right about $440 before shipping.
    I plan on using the method in the video to replace the fronts, seems WAY safer than using the spring compressors since it’s all bolted in the spring can’t go anywhere if a failure happens, and no tools but a floor jack needed. Yes I know the video is a Tacoma. Process is the same except you need to unbolt the sway bar link from the lower for the Tundra.
    https://youtu.be/vkVLBOnAifc
  11. Feb 2, 2019 at 9:09 AM
    15whtrd
    15whtrd Mr. Blonde
    That was really simple.
  12. Feb 2, 2019 at 9:19 AM
    Jrharvey02
    Jrharvey02 New Member
    My truck is stock too and I just replaced shocks all around with TRD Sport (Bilsteins; the red and blue ones). Got them as take-offs with only a couple hundred miles from this site, $200 total. Ptr13-34070 and ptr13-34071. Says they’re for 2WD only but that is incorrect and I have verified with Toyota. Couldn’t be happier with mine, especially considering the price.
    Toyfan2[OP], 15whtrd and Trooper2 like this.
  13. Feb 2, 2019 at 10:58 AM
    Toyfan2
    FL
    Thanks Kevin, excellent video, I think this is the way I will go. Were did you price the 5100s?
  14. Feb 2, 2019 at 11:04 AM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    Toyfan2[QUOTED][OP] and kparrow like this.
  15. Feb 2, 2019 at 11:10 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I priced them both on RockAuto.com and on Amazon. RockAuto was just a tad bit more but I’ll probably end up ordering them from them anyways. All parts coming from one vendor makes stuff simple for me. Amazon links are below. Note you don’t necessarily need new top hats or rear bushings but I figured it can’t hurt while I’m already going through the effort, and my truck has 120k on it, so the bushings are probably pretty solid at this point.
    Hopefully in the next few months I can pull the trigger. Convinced my wife already to let me do audio on the truck....so I have to let those purchases ride for a little bit :rofl::rofl:
    Bilstein 5100 Series Shock Kit for Toyota Tundra 4WD 2007-14 - Includes Front Ride Height Adjustable Shocks # 24-232173 & Rear Shocks # 24-186971 by Bilstein https://www.amazon.com/dp/B01LRJ88EC/ref=cm_sw_r_cp_api_i_3OEvCbYRW35YA
    KYB SM5737 Mount Kit https://www.amazon.com/dp/B0142SLVXK/ref=cm_sw_r_cp_api_i_pPEvCb05M2TZT
    Gabriel 143340 Suspension Mount https://www.amazon.com/dp/B00DBS4OSC/ref=cm_sw_r_cp_api_i_WPEvCbT9YQC93
    Toyfan2[OP] likes this.
  16. Feb 2, 2019 at 11:19 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
  17. Feb 2, 2019 at 12:03 PM
    Steve89gt
    2018 Limited CM
    I just had 5100s installed to replace a Ready Lift bracket kit; I was out the door for $1100 installed, with a diff drop and an alignment. Couldn’t be happier with the ride quality, much better than with the 4600s + brackets
    kparrow[QUOTED] likes this.
  18. Feb 2, 2019 at 12:08 PM
    Toyfan2
    FL
  19. Feb 2, 2019 at 12:10 PM
    fliberto38
    fliberto38 New Member
    Frank
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
  20. Feb 2, 2019 at 12:35 PM
    Toyfan2
    FL
    kparrow and fliberto38[QUOTED] like this.
  21. Feb 2, 2019 at 10:16 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    fliberto38[QUOTED] likes this.
  22. Feb 3, 2019 at 6:03 AM
    Toyfan2
    FL
    OK, I see a push for leveling, +1, +2. My question, Do you level just for looks? Is this changing the geometry of the front end? Like I really know what I'm talking about. Should I stay or should I go.... I have a while to ponder this before the parts come in. Thoughts?
    kparrow likes this.
  23. Feb 3, 2019 at 6:46 AM
    I'm going to put Bilstein 5100's on the middle setting on the front to level it out. Mainly doing it for looks. My Tundra is a pavement princess, there is no place around here for off roading.
  24. Feb 3, 2019 at 6:48 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I plan to level it (middle perch). Every truck is different but it should bring it within about 3/4 of an inch of the back stock, which looks darn near level, good enough for me. For mine it will probably be level because I have a toolbox in the bed with about 150-200 lbs of gear.
    My understanding is no, it does not change the geometry of the front suspension because you are still working within the normal range of motion, just slight additional preload on the coil spring=lift.
    Need to get an alignment afterwards regardless of stock height or leveled, the choice is yours :)
    Also take into consideration if you tow or carry heavy loads often, the rake is there to level the truck under load so you will be a bit squatted if you’re level at no load. I personally don’t at this point and if I begin to tow something heavy on the regular, I’ll get airbags anyways.
    Toyfan2[QUOTED][OP] and 15whtrd like this.
  25. Feb 3, 2019 at 7:56 AM
    15whtrd
    15whtrd Mr. Blonde
    Just leveling for looks and ground clearance. But if you set those shocks on the lowest setting it will be pretty much stock hight with a better shock.
  26. Feb 3, 2019 at 10:05 AM
    15whtrd
    15whtrd Mr. Blonde
  27. Feb 3, 2019 at 10:13 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed Bilstein 4600 series shocks all the way around on my '07 Tundra, the original shocks had 270k on them.
    15whtrd likes this.
  28. Feb 3, 2019 at 10:22 AM
    Rex Kramer
    Georgia
    kparrow and 15whtrd[QUOTED] like this.
  29. Feb 3, 2019 at 10:32 AM
    Toyfan2
    FL
  30. Feb 3, 2019 at 10:33 AM
    15whtrd
    15whtrd Mr. Blonde
    Too late to cancel?
