Driver’s Side Grab Handle...
Discussion in '2.5 Gen Tundras (2014-2021)' started by sbbrown333, Feb 2, 2019.
  1. Feb 2, 2019 at 5:47 AM
    sbbrown333
    sbbrown333 [OP] MGM Wrecking Crew
    Blake
    2018 MGM Limited CM 4x4
    Am I crazy? I feel like this should line up better. It’s been installed a few weeks now but it doesn’t line up straight on the front window border like the passenger side does. Let me know what you think. Did I overtighten it? It lines up perfectly with the rubber piece on the door side.
  2. Feb 2, 2019 at 6:08 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I don't disagree but it looks just like mine.
    Scpringle and Black Wolf like this.
  3. Feb 2, 2019 at 6:11 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I had a similar situation.
    When the temps rise like in the summer months it should relax the Plastic.
    sbbrown333[OP] likes this.
  4. Feb 2, 2019 at 6:14 AM
  5. Feb 2, 2019 at 7:00 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Mine's a little off as well. Completely forgot about it until now. Thanks for that. :p
    JPritch, rmorse, Johnmatrix and 6 others like this.
  6. Feb 2, 2019 at 7:00 AM
    deedubb
    deedubb New Member
    2018 Tundra SR5
    Looks like it’s defective. I’ll but it from you at a slight discount :D
    koditten likes this.
  7. Feb 2, 2019 at 7:09 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    Loosen it up a bit, wiggle it around and reseat it maybe?
  8. Feb 2, 2019 at 7:43 AM
    sbbrown333
    Blake
    I thought about that too. Glad to see it’s just the way it is. I felt liked I needed to loosen it anyway since it’s a little tight on the fabric at the top compared to the passenger side.
  9. Feb 2, 2019 at 7:51 AM
    wh4x4
    wh4x4 New Member
    Yup, I thought the same thing and was worried I over-tightened. So I tried to back it off, it just made the handle give a bit when pulling on it, so I tightened it back up. So thats just the way it is. Mine looks exactly the same.
    NewImprovedRon likes this.
  10. Feb 2, 2019 at 8:25 AM
    marlin39a
    marlin39a I’m a dumbass.
    Where can I buy the grab handle for my 2019 Tundra?
    Bdk437 likes this.
  11. Feb 2, 2019 at 8:31 AM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    You can place a Ram mount on the lower handle mount, removes the Ill fitting cover and a great place for your phone
    BOSSARU, ttundra10, koditten and 3 others like this.
  12. Feb 2, 2019 at 8:32 AM
    @Roman send him a PM.
    Roman and NewImprovedRon like this.
  13. Feb 2, 2019 at 8:33 AM
    Jake do you have a link?
  14. Feb 2, 2019 at 8:39 AM
    wh4x4
    wh4x4 New Member
    I got mine from Sparks Parts as it came with the additional parts needed (u-nut and bolt)
    daven likes this.
  15. Feb 2, 2019 at 8:40 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Yup. I had to get 3 peices total to make it all work. If you're spacing isnt right, the ball mount will spin when tightening, have a few washers on hand for that. Hit me up if you need any further info
    Ram Mount Cradle Holder for Universal X-Grip Cellphone/iPhone with 1-Inch Ball - Non-Retail Packaging - Black https://www.amazon.com/dp/B0055PH0XA/ref=cm_sw_r_cp_apa_i_oCCvCbH8YG078
    Ram Mount Double Socket Swivel Arm for 1-Inch Ball Bases https://www.amazon.com/dp/B009SX0J88/ref=cm_sw_r_cp_apa_i_YECvCbFY668HQ
    Ram Mount Motorcycle Handlebar Clamp Base with M8 Screws https://www.amazon.com/dp/B005J43I56/ref=cm_sw_r_cp_apa_i_iFCvCbN8HJT39
  16. Feb 2, 2019 at 8:41 AM
    :thumbsup:
    CaptSpaulding[QUOTED] likes this.
  17. Feb 2, 2019 at 9:02 AM
    marlin39a
    Thanks for the link. I need this mod.
  18. Sep 6, 2021 at 6:11 PM
    mrcocoa
    mrcocoa New Member
    Joe
    2019 Tundra SR5
    All stock
    Went to Sparks and according to the sote the part does not fit my truck? Anybody have a comment? 2019 Tundra SR5
  19. Sep 6, 2021 at 6:44 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It'll fit.
  20. Sep 7, 2021 at 3:02 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Normal, all the handles I’ve seen have that slight imperfection/defect.
    stuckinohio likes this.
  21. Sep 7, 2021 at 3:52 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You'll just have to modify it slightly to fit around the air bag wiring. Copy the general shape of the old one after you pull it out.
  22. Sep 7, 2021 at 5:11 AM
    justcuz
    justcuz 2.5 Gen Member
    My 2018 SR5 Off-road does not have a drivers side grab handle. Only on the passenger side.
  23. Sep 7, 2021 at 5:31 AM
    Bammer
    Monroe, CT
    You can add it like we all did.
    IA_Tundra likes this.
  24. Sep 7, 2021 at 10:00 AM
    Bammer
    Monroe, CT
  25. Sep 7, 2021 at 12:22 PM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    Sparks here as well.. Caught a sale a while back, comes with the extra hardware that makes it a simple install. Mine is off a bit as well, not as bad as yours though.. The little bolt cover doesn't fit great on mine, popped out once, but its staying in now.
  26. Sep 7, 2021 at 10:01 PM
    Nubby
    Nubby New Member
    AZ
    2021 TRD Army Green
    Is this handle from Sparks a Toyota OEM part?
  27. Sep 8, 2021 at 4:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Yes, but for different years/models. Since Toyota has not changed the design of that pillar, though, it fits just fine in newer trucks. The only thing I had to do to make it work for my 2020 was to cut out the notch (hidden once installed) for the airbag wiring.
  28. Sep 8, 2021 at 5:18 PM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    Mine has a very slight bend. I installed it last year.
  29. Sep 8, 2021 at 10:21 PM
    Diesel_dave
    Diesel_dave New Member
    did these match the color interior? cause i just see tan and gray
  30. Sep 9, 2021 at 12:39 AM
    Blue By U
    Blue By U New Member
    Why is there so much debate over fitment, color or OEM. The thing will fit up to 2021. Takes 10min to install.
