Rear Diff Not Centered
Discussion in '1st Gen Tundras (2000-2006)' started by pacop, Feb 1, 2019.
  1. Feb 1, 2019 at 10:42 AM
    pacop
    pacop [OP] New Member
    Paco
    Puerto Rico
    2006 Tundra Limited Double Cab 4WD
    Hello everyone,I noticed that the passenger rear tire sticks out more that driver rear tire. I have a 2006 DC with KO2 285/70R17. Is this normal on first gens? bctmRKb4RoCdfWmJLZ%c6w.jpg %RCL2auWT4OfQGeFOuIJwg.jpg
  2. Feb 1, 2019 at 10:48 AM
    15whtrd
    15whtrd Mr. Blonde
    I know that’s the way it is on my 2.5 gen.
    Sunnier likes this.
  3. Feb 1, 2019 at 10:57 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    Not normal, but fixable.
    1)Make sure there is nothing keeping the wheels from fitting flush. (Clean around the hub and brake rotor mount and inspect.)
    2) make sure the bed is aligned (harder then the first step of it is not straight)
    3) if all that checks out, make sure your suspension and drive line are not bent. You can get new Ubolts and shift the axle what ever direction you need.
  4. Feb 1, 2019 at 11:00 AM
    15whtrd
    15whtrd Mr. Blonde
    Go check your truck. Ours are off-center. I centered my bed and it’s still off a little bit.
  5. Feb 1, 2019 at 11:34 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Go measure other Tundras. Heck, go measure any other truck you see. Pretty common.
    I don't lose sleep over that kind of stuff if everything else checks out. Now the drivers side lean, that drove me nutz.
    15whtrd likes this.
  6. Feb 1, 2019 at 11:39 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The driveshaft spends 99.999% of it’s time twisting in one direction. I’ll bet over time this bends things a little right?
  7. Feb 1, 2019 at 11:40 AM
    15whtrd
    15whtrd Mr. Blonde
    It’s twisting the axle or rotating it but not side to side.
  8. Feb 1, 2019 at 12:08 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Forget the bed to tire.
    Measure from frame to tire instead, if possible measure from frame to the backing plate where your drum brakes are, then from frame to where your inner tire edge starts to see if there is a difference.
    If that checks out, then measure from frame to bed and this will tell you if the bed is offset, if so just live with it.
  9. Feb 1, 2019 at 5:04 PM
    pacop
    Paco
    Puerto Rico
    I measured from the frame to the tire and the passenger side is further out. I’ll take to the shop that installed the suspension have them check it out. If everything is ok I can live with it. I did not notice it until I began to measure to have a shop make me slider since ordering a pair and having ship to Puerto Rico would cost me a lot more
  10. Feb 1, 2019 at 5:27 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    My buddy had a 2010 DC I believe and I remember he noticed this exact thing when he put aftermarket wheels and tires on- the garage was like “look at this” when it was on the lift. Seems pretty common.
