What's needed to change to get 3" in the front?
Discussion in 'Suspension' started by Cacoleman2014, Jan 31, 2019.
  1. Jan 31, 2019 at 12:37 PM
    Cacoleman2014
    Cacoleman2014 [OP] New Member
    Louisiana
    2006 Tundra SR5 double cab
    I want to raise my truck up a bit. I am stuck between just leveling and adding that extra inch.. Is there anything I have to change to safely raise 3 in the front?
  2. Jan 31, 2019 at 12:41 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Upper control arms
  3. Jan 31, 2019 at 12:43 PM
    Cacoleman2014
    Louisiana
    On a budget .. Any suggestions on brand or a inclusive kit?
  4. Jan 31, 2019 at 1:04 PM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    Cacoleman2014[OP] and Netmonkey like this.
  5. Jan 31, 2019 at 1:04 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Look into bilstein 5100s, they're adjustable. 3 settings. Better ride than a spacer lift. Anything over 3" you need new ucas. 3" and under you'll be fine.
  6. Jan 31, 2019 at 1:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Uca or not, you dont want more than 3 inches of lift. Even going to 3 inches rides like crap due to the a arm angle
  7. Jan 31, 2019 at 1:35 PM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    I just lifted mine 3 inches with the Toytec Boss kit, upper control arms and shackles. Rides better in my opinion, but also went down to 18" wheels for more sidewall on my tires.
    Berdine likes this.
  8. Jan 31, 2019 at 2:22 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The picture on his profile shows a gen 1, which has shorter control arms. Those ride pretty rough when you go over 2 inches in my experience
  9. Feb 1, 2019 at 10:36 AM
    Cacoleman2014
    Louisiana
    It is a first Gen. I put the AT3's on it with 1 1/2 spacers and I have a little bit of rub. I averag 18, 000 miles a year and most is freeway, though I do pull a trailer for work occasionally or my camper. I definitely don't want to sacrifice too much ride comfort, but the tire rub drives me crazy.
    Berdine likes this.
  10. Feb 1, 2019 at 10:41 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    What’s the a arm?
  11. Feb 1, 2019 at 11:05 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    What size tires?
  12. Feb 1, 2019 at 12:34 PM
    Cacoleman2014
    Louisiana
    265 70 17
  13. Feb 1, 2019 at 12:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Those are rubbing? Maybe they are just hitting something plastic that can be trimmed
  14. Feb 1, 2019 at 1:01 PM
    Cacoleman2014
    Louisiana
    Not bad just when turning on a dip or incline
