2010 Tundra Odd Noise
Discussion in '2nd Gen Tundras (2007-2013)' started by 2O1OTundra, Jan 26, 2019.
  1. Jan 26, 2019 at 6:17 PM
    2O1OTundra
    2O1OTundra [OP] New Member
    Jerry
    2010 Tundra CrewMax
    Hello - I have a 5.7 CrewMax with 125k. For the past 15k miles or so I'm having an odd noise coming from the front passenger side of the motor. I really only notice it when sitting inside the truck. I would say it sounds like a groaning crossed with rattle. If I'm driving at low speed in a parking lot I notice it. If I put it in park and rev the engine a little I can hear it. Also right when I turn off the truck I can hear it for a split second.
    I've checked all my exhaust heat shields and they are good. The sound really wasn't coming from that area anyway. I think it may be a bad passenger side motor mount, but the motor runs smooth with no vibrations. Has anyone else experienced this, or need to change out their motor mounts because of a similar noise?
  2. Jan 28, 2019 at 5:21 AM
    Jkreid50
    Jkreid50 New Member
    Joshua
    2012 Tundra double cab
    33" Arturo Trail Blades, 3" lift/level kit, rancho shocks
    Check your wiring harness that's attached to the firewall on the passenger side. A Lot of times as the engine moves, and the wiring harness twists in this holder it makes a squeak or groaning sound. Open the holder and drive like you did when it was making the noise...I just wrapped mine with a bit of teflon tape, problem solved. Hope this helps!
    2O1OTundra[OP] and sdde4n like this.
  3. Jan 28, 2019 at 6:39 AM
    2O1OTundra
    Jerry
    2010 Tundra CrewMax
    Thank you I'll take a look at this tonight.
  4. Jan 29, 2019 at 12:30 PM
    Jkreid50
    Jkreid50 New Member
    Joshua
    Did you get a chance to take a look? Was that the issue?
  5. Feb 1, 2019 at 10:23 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Leitner Designs ACS
    I had something very similar with my 2014 DC and the fix described here is exactly what the dealership did to take care of it.
    2O1OTundra[OP] likes this.
  6. Feb 1, 2019 at 10:25 AM
    2O1OTundra
    Jerry
    2010 Tundra CrewMax
    Sorry I took so long to reply, but you are spot on. This was where the noise was coming from. THANK YOU!
  7. Feb 1, 2019 at 10:27 AM
    Jkreid50
    Jkreid50 New Member
    Joshua
  8. Feb 1, 2019 at 10:35 AM
    sdde4n
    sdde4n New Member
    Leitner Designs ACS
    Serious, well done, bro.
    Jkreid50 likes this.
