  1. Jan 29, 2019 at 4:48 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That's BA! I love it...
  2. Jan 29, 2019 at 4:53 PM
    Thanks
  3. Jan 29, 2019 at 5:18 PM
    Mattp81
    Mattp81 New Member
    That is slick! Did you get the leather one off ebay?
  4. Jan 29, 2019 at 5:22 PM
    mesaboogieman likes this.
  5. Jan 29, 2019 at 5:26 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Did I miss a write up on the install?
  6. Jan 29, 2019 at 5:36 PM
    Yes
    I think I wrote it.
    Here.....
    Pull trim(silver) around shifter off
    Unscrew shifter knob
    Put cover over shaft, tuck it in about 1/2" all around
    Snap cover back on, cover holds it in place.
    Screw shifter knob back on. ** If replacing with Tacoma Pro knob (what I used) you have to cut the outer white plastic off the bottom of the knob and shave the raised plastic so the metal ring on the boot fits to the bottom of the Tacoma Pro knob.
  7. Jan 29, 2019 at 5:58 PM
    HappyGilmore
    Trent
    Lakewood CA
    Thanks!
  8. Jan 29, 2019 at 5:59 PM
    :thumbsup:
  9. Jan 29, 2019 at 6:18 PM
    Mediumrarepls
    Mediumrarepls New Member
    2019 Tundra SR5 TRD Offroad Crewmax Quicksand 4x4 5.7
    My flairs had about 5 screws underneath that go into the fender. The bolts you have in the picture have nuts behind them.
  10. Jan 29, 2019 at 6:36 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thanks! And yessir, Shackle brackets from Elevated Suspension.
  11. Jan 29, 2019 at 6:40 PM
    Sakana65
    Sakana65 New Member
    Gary
    2017 Pearl blue trundra
    I added a Magnuson Super Charger, since this will my last truck. I am 60 yr old guy, decided to skip the lift but give myself power.
    cjmay13, Shark Bait, Ostrich and 13 others like this.
  12. Jan 29, 2019 at 6:40 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Damn u Jim, I think I love the new 1 better. By time this is over I'm gonna have a 100 dollars in $10 shifter boots lol.
  13. Jan 29, 2019 at 8:26 PM
    Devildawg712
    Devildawg712 New Member
    Union City, Ca
    2020 Marine Corps Green Sequoia. (SEQUNDRA) Past~~ 17' Cement TRD PRO (FUNDRA)
    Finally pulled the trigger and scheduled an appt with @milogenfab for the BMC. Also purchased some +3 inch shackles and shims from Coachbuilder. Gonna link up with @dcsleeper408 for the install once the BMC is done for the Shackle/shim install.
    I'm doing the BMC / Shackles and Shims in preparation for a larger wheel/tire setup. Most likely 35's, but the damn Mod bug got me and now I'm wanting to just pull the trigger on the 35's.
    I'm debating on either purchasing the 35x12.5's now or just waiting till my KO2's are worn. Problem is, they've only got 10k miles. I know the difference between 305/65 isn't that much, but like I said, the mod bug got me. I may end up just keeping this setup intact and buying a whole new wheel/tire setup. I've really taken a liking to the SCS Ray 10's in Matte Dark Bronze. I parked by a cement Trd Pro 4runner with Matte Bronze wheels and thought it looked pretty dope.
    my setup may go up for sale if I end up buying those. If not the *lightly used Ko2's will be :thumbsup:
    Trying to decide between 4 tires for the 35's:
    BF goodrich Ko2
    Toyo Open Country R/T
    Nitto Trail Grappler
    or Cooper Discoverer STT if I can find it in an 18' ( may be discontinued)
    I'll upload the after pic once its all done.
    TRD PRO SHIM KIT W: BUMP STOP EXTENSIONS .jpg
    cjmay13, Major, Ostrich and 10 others like this.
  14. Jan 29, 2019 at 8:42 PM
    Thanks Mike. It probably matches your Pro seats.
    :rofl::rofl::rofl:
    mgm16trdpro[QUOTED] likes this.
  15. Jan 29, 2019 at 8:57 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    How much did those bumpers run? Looks awesome. Sensors work???
  16. Jan 29, 2019 at 9:03 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Glad I could help!
  17. Jan 29, 2019 at 9:10 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Seems like a lot of people have been switching to the toyo RT. I like it because it’s a hybrid between a m/t and an a/t. Your truck looks good either way though. That light bar setup in the bulge really adds aggressiveness to the front end.
    Devildawg712[QUOTED] likes this.
  18. Jan 30, 2019 at 7:41 AM
    Disfigurative
    Disfigurative New Member
    james
    18 black TRD sport
    Painted (Plasti dipped) tow hooks red.
  19. Jan 30, 2019 at 9:17 AM
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Installed ‘19 TRD PRO LED Headlights
    Edit: thanks @iHacker for the harness, great product and the write up was helpful.
  20. Jan 30, 2019 at 10:27 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    Looks very nice. Thats something I would like to do. Just one question, why plast dip? You took the time and effort to remove them, paint them and reinstall them. Why not powder coat them? I would not use plasti dip on our trucks at all. Hope it lasts.
  21. Jan 30, 2019 at 11:19 AM
    Disfigurative
    james
    18 black TRD sport
    I wasn’t sure if I would like it. Plasti Dip will peel right off if I want to go back to black. Its mostly a temporary thing. But it will last for a really long time. If I need to actually use the hooks it will probably peel in that location. As far as mods go it doesn’t get any easier than popping off 4 bolts sprayin some Plasti Dip and popping them back on.
    Degausser likes this.
  22. Jan 30, 2019 at 11:22 AM
    FirstTruck
    Stock, for now
    Definitely on my list
    Disfigurative[QUOTED] likes this.
  23. Jan 30, 2019 at 11:23 AM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Nothing wrong with plasti dip as a super cheap temporary option. That's what I did with my bumper end caps, and you legitimately can't tell at all.
    Disfigurative likes this.
  24. Jan 30, 2019 at 11:36 AM
    Disfigurative
    james
    18 black TRD sport
    I used it as a temporary fix on my wheels and it came out so good I might not even get new wheels now
    Beckusmc, cjmay13, Okietundra and 7 others like this.
  25. Jan 30, 2019 at 11:41 AM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Damn that looks great
  26. Jan 30, 2019 at 11:52 AM
    pannelld
    pannelld New Member
    Dustin
    Toyota Tundra 2014
    20 inch fuels on 33" Toyo Trail Grapplers
    What all did you have to do when you put those lights in? I have a 2015 SR5 and I'm pretty intimidated to put those headlights in.
    Okietundra likes this.
  27. Jan 30, 2019 at 12:05 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I have been thinking of treating my chrome bumper caps with a product I already have under a different brand name marketed by Armor All, called something like Pro-Shield. I do t have a can in front of me, but I had previously used it to color a BMW front spoiler. There was some shipping and road rash, etc. the project took about a half hour and it looked great. I was thinking I would have to replace it after a few months but it kept lasting and lasting for years. Car washes, Blizzards, you name it! I ended up buying several cans thinking I would just repeat the process, but never saw the need.
    Anyhow, with that success, I was toying with the idea of doing the tundra front chrome caps as a quick and dirty way to get the color change. Easy on and easy peel if I want to revert.
    I read your post and was wondering about what people meant by plasti dip, thinking it was some sort of plastic coating involving removal and treating parts for a semi permanent color costing. I looked it up and it looks to be the same or similar spray-on product.
    Is the plasti dip you treated your caps with matte black finish? Did you add a gloss treatment for finish or were you able to buy it in a gloss finish?
  28. Jan 30, 2019 at 12:11 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Here's a thread by iHacker on how to upgrade the halogen headlamps to the new LED headlamps.
    You will need to order the headlamps from @Roman of Cool Springs Toyota and the wiring harness from @iHacker. It will cost you around $750 for this upgrade.
    https://www.tundras.com/threads/201...lay-harness-for-2014-2017-models-v-2-0.24416/
    Okietundra, Norfolk757 and Roman like this.
  29. Jan 30, 2019 at 12:15 PM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    Hammerhead, equin, GAknight and 12 others like this.
  30. Jan 30, 2019 at 12:50 PM
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Buy the harness from @iHacker and refer to his thread. I had to remove the grille and body panel below the headlamps. There are a few more steps involved for the SR5 installation since they don’t have LED DRL. All in all it took me a couple hours.
    XDS and iHacker like this.
