Bedliner - DIY?
Discussion in 'General Tundra Discussion' started by GreatBigAbyss, Jan 29, 2019.
  1. Jan 29, 2019 at 9:30 AM
    GreatBigAbyss
    GreatBigAbyss [OP] New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    I want to do a DIY bedliner, with a kit.
    What's a better option? Roll-On? or Spray-on? I have access to a decent size compressor if I do spray-on.
    I assume both require similar amounts of prep, scuffing the box, etc. I imagine the spray-on would also require significant masking in order to prevent overspray. Which type holds up better to abuse?
  2. Jan 29, 2019 at 9:34 AM
    A friend of mine did both. He sprayed the corners, seams and under the bed rails (spots hard to get with a roller), then he rolled out the bed.
