Electrical question
Discussion in 'General Tundra Discussion' started by jeremyd, Jan 28, 2019.
  1. Jan 28, 2019 at 6:53 AM
    jeremyd
    jeremyd [OP] 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I am currently working on a light bar and was wondering if I grabbed 12 volts from the fog light to drive a standard 40 amp relay would that work ? I would like to eliminate the in cab switch and just use the fog light switch on the column to turn on the light bar. Any suggestions would be helpful. I am just a backyard mechanic, lol
  2. Jan 28, 2019 at 7:57 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    HOw many amps is the light bar? I personally wouldn’t want my light bar on all the time but that’s just me.
  3. Jan 28, 2019 at 8:01 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The light bar specs say 8 amps. It would only be on when you turn on the fog lights.
  4. Jan 28, 2019 at 8:04 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    Use the fog lamp +12v for the coil on a relay. Get your 12v+ direct from the battery.
    040Tundra and jeremyd[OP] like this.
  5. Jan 28, 2019 at 8:05 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Thank you ! I just wasn’t sure of myself !
