Remote starter install mystery
Discussion in 'General Tundra Discussion' started by Blewis, Jan 26, 2019.
  1. Jan 26, 2019 at 3:41 PM
    Blewis
    Blewis [OP] New Member
    2011 Tundra
    Hello all. I have a mess going here. I am nearly sick over the matter. Any help would be much appreciated. Here goes. Bought remote starter from 12 volt solutions. Followed install step by step. Worked once and now does not work. 2011 tundra is what I have. So before I give details of what is happens it does anyone have experience with this topic? Please help! I have my dash torn apart and bad weather is coming.
  2. Jan 26, 2019 at 3:42 PM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Did you contact 12 Volt Solutions?
  3. Jan 26, 2019 at 3:46 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Do you have a cutout in the circuit?
    My 2003 Tundra came with remote start. There seems to be a button on the dash that basically shuts off the feature. I think it's the cargo lamp switch, but haven't looked too closely at it yet. (Too many burned out bulbs in my dash, I randomly hit the wrong buttons. Still figuring out my 'new' truck.)
  4. Jan 26, 2019 at 3:47 PM
    Blewis
    2011 Tundra
    Yes they are not open on weekends. Of course.
  5. Jan 26, 2019 at 3:57 PM
    Blewis
    2011 Tundra
    I am unsure if there is a cutout in circuit. When I installed the remote starter it worked one time. The first time it worked great. Then after that installed the phone app portion. Then nothing worked. When I push the lock button three times the yellow parking lights flash four times and then nothing happens except the truck will actually unlock itself beep like I have hit the unlock button on keypad but I didn’t. It is driving me crazy.
  6. Jan 26, 2019 at 4:01 PM
    Could a fuse have blown or a wire got loose?
  7. Jan 26, 2019 at 4:31 PM
    Blewis
    2011 Tundra
    I don’t think so but obviously I’m not the authority of the matter. All the lights and stuff are consistent with video.
  8. Jan 26, 2019 at 4:54 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I would contact the dealer Monday and try not to stress out too much.my remote start stopped working on my truck and I looked it up and found out I had a valet button on the remote.
  9. Jan 26, 2019 at 5:12 PM
    Blewis
    2011 Tundra
    How did you turn that off?
  10. Jan 26, 2019 at 5:26 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I had a wire crimp come loose, I crimped it to tight and broke the wire. It took a few day to come completely apart and show a problem.
    Your problem sounds like it has something to do with the app, can you take the wireless stuff out? I don’t have the wireless so I don’t know anytabout it.
  11. Jan 26, 2019 at 6:24 PM
    Blewis
    2011 Tundra
    Yeah I took that stuff off. When I hit the lock button three times the parking lights flash four times and then it double beeps and unlocks driver door. When I first hooked it all up it worked great once then from there on won’t do anything.
