KB Voodoo Premium Bed Rack for Tundras
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by KB Voodoo, Jun 15, 2017.
  1. Jan 25, 2019 at 8:22 AM
    #181
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I live in Bay Area in a small coastal town called pacifica about 10-15 minutes from SF. About a mile or two from the Ocean. It seals pretty well, but I’m going to add some black silicone around the entire edge of it to see if it helps with dust just to try it. I’m sure without the rack dust still gets in but it’s worth a try. As for water I can’t face downhill cause water will sit in the corner of the truck. Hopefully the silicone will help with this. Just park facing uphill and it’s fine. When driving in rain storms it seals just fine cause the water is running off of it.
    Sunnier likes this.
  2. Jan 25, 2019 at 8:30 AM
    #182
    Sunnier
    Sunny
    San Diego, CA
    Thanks for the reply.
    Before I installed a Steel Max rack, I mounted a neighbor's tonneau cover for a week-long road trip through the Southwest; lots of dirt roads. The bed was filled with dust, especially near the two gaps on either side of the tail gate. On here I read that's where most water gets in too.
  3. Jan 25, 2019 at 8:35 AM
    #183
    KB Voodoo
    KB Voodoo [OP] New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    My bed is filled with dust with the tonneau cover on even without the rack installed. It's not a hermetically sealed container.
  4. Jan 25, 2019 at 8:56 AM
    #184
    Jimes
    Jimes New Member
    Ya I figured. Unless we add some weatherstripping on the tailgate and try to close off all holes, but even then. When on a dirt road dust finds a way.
    Sunnier likes this.
  5. Jan 25, 2019 at 8:58 AM
    #185
    Jimes
    Jimes New Member
    I will try to add the weatherstripping and seal holes then go wheeling and will post up results. Unfortunately that won’t be for a while. It I did just add my roof top tent to my rack. Just need to put my road shower, awning and maxtrax back on to be complete.
    Sunnier likes this.
  6. Jan 25, 2019 at 9:01 AM
    #186
    Sunnier
    Sunny
    San Diego, CA
    That was my point
  7. Jan 25, 2019 at 10:23 AM
    #187
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    @Jimes is that the 22” rack?
  8. Jan 25, 2019 at 11:35 AM
    #188
    Jimes
    Jimes New Member
    It’s the tallest they make.
  9. Jan 26, 2019 at 2:24 PM
    #189
    Jimes
    Jimes New Member
    Had to move maxtrax onto the passenger side to make the driver side the entrance. Plus had to customize my custom awning mounts that milo made. I have a road shower that goes onto the passenger side above the maxtrax to help with the gas tank weight on the drivers side. But I’m fully functional now. Now I have to put it to work on a trail. 142D4E5E-B94C-468F-B21E-CFED82FEA7AF.jpgF055F90D-E9D5-41B9-862F-654FA7D1A357.jpgA4999538-0023-43F9-A9A2-75645D2C8DA3.jpg
  10. Jan 26, 2019 at 2:46 PM
    #190
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    @KB Voodoo would you mind PM’ing site code?
  11. Jan 26, 2019 at 4:52 PM
    #191
    KB Voodoo
    Chad
    PM’d
  12. Jan 29, 2019 at 4:20 AM
    #192
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    Same please
  13. Jan 29, 2019 at 5:18 AM
    #193
    KB Voodoo
    Chad
    PM’d
    tbrown[QUOTED] likes this.
  14. Jan 29, 2019 at 1:31 PM
    #194
    Phantastic81
    Phantastic81 New Member
    2011 matte white CrewMax
    KING 2.5 COIL OVER all around . 20 Inch WORX wheel on 34's Roll n Lock cover. Go RHINO Bull Nose Bar Grill , GO RHINO Side Steps ,Volant air intake ,flowmaster dual exhaust. tinted OEM front n rear lights, 2018 Sequoia headlights ,kb voodoo 20 inch bed rack,rhino rack platform ,
    same please
  15. Jan 29, 2019 at 2:43 PM
    #195
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @KB Voodoo what rolling cover do you recommend with your rack? Which one would you get? I was looking at the revolver x4 but looking for opinions. I want to be able to open the cover with the rack on.
  16. Jan 29, 2019 at 2:57 PM
    #196
    KB Voodoo
    Chad
    We recommend the Pace Edwards Switchblade and Retrax.
    See our Tonneau Fitment Guide here: https://www.max-modular.com/tonneau-cover-fitment-guide/
  17. Jan 29, 2019 at 9:46 PM
    #197
    svitosky
    svitosky New Member
    Stephen
    2018 Tundra Limited SSM
    @KB Voodoo Could I get a site code as well? Thank you
  18. Jan 30, 2019 at 4:02 AM
    #198
    KB Voodoo
    Chad
    PM’d
  19. Feb 9, 2019 at 7:50 AM
    #199
    Jimes
    Jimes New Member
    Anyone put a third brake light on there rack since it covers the stock one on the truck with RTT? If so, what did you use? Need to add one.
  20. Feb 9, 2019 at 8:14 AM
    #200
    BlueBottle
    '16 Platinum 4x4
    See fine print
  21. Feb 9, 2019 at 8:27 AM
    #201
    Jimes
    Jimes New Member
    BlueBottle[QUOTED] likes this.
  22. Feb 9, 2019 at 8:29 AM
    #202
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Haha better to over build that under. They make a smaller one too but doesn’t have the ambers. I like the ambers. Would work well as dust/rear fog lamp.
  23. Feb 9, 2019 at 9:11 AM
    #203
    Jimes
    Jimes New Member
    I agree. I decided to check out rigid since all my lights on my truck are rigid. They have a 2x7 chase light that does everything as well except for turn signal. I would do like 2 or 3 of them. They are a little bit bigger than the rack itself. The center brace is like 1 3/4” so it would overhang. But the Baja designs wouldn’t. Hmm.
    https://www.rigidindustries.com/chase-chase.html
  24. Feb 9, 2019 at 9:47 AM
    #204
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Those are nice. It would be a good setup to have 4. 2 reds in the middle and amber on the outsides. You can use the reds as brake lamps and marker. Amber for fogs/dust.
    Jimes[QUOTED] likes this.
  25. Feb 9, 2019 at 10:01 AM
    #205
    Jimes
    Jimes New Member
    Ya after looking at the rack it would more than likely be 3 of the rigid ones. One in the middle and two on the corners. But if I do go that route I’ll buy one first as a sacrificial lamb to see if I like the fit and light output. At 240 a piece I’d try the middle one firstand if all goes well add the other two.
  26. Feb 9, 2019 at 10:07 AM
    #206
    TheBeast
    TheBeast The Beach
    @Jimes nice setup. You running 35" on your 18" rims ?
    I lived in Pacifica in the early 2000's. Nice coastal town. I don't miss the fog though :)
  27. Feb 9, 2019 at 11:26 AM
    #207
    Jimes
    Jimes New Member
    Thank you and yes for for now. I want 37s when the 35s wear out. Pacifica fog can be thick at times. More so at the top of pacifica where my mom lives. I live closer to the beach in a valley so we tend to have a microclimate that is different than upper pacifica. Just don’t like the one way in and one way out of my neighborhood. If and when highway 1 has issues I’m pretty much screwed. Other than that I’ll probably stay here for the rest of my life if possible.
    TheBeast[QUOTED] likes this.
  28. Feb 9, 2019 at 11:28 AM
    #208
    TheBeast
    TheBeast The Beach
    yeah it's definitely a nice town that doesn't make you feel you are in the Bay Area. Also a cool gun shop there.
    I used to live on top of the hills. Best sunsets ever from the living room.
  29. Feb 9, 2019 at 11:32 AM
    #209
    Jimes
    Jimes New Member
    I used to live in the apartments above that gun store next to the castle. Yes we have a castle in pacifica. And ya it’s definitely not your typical city life. That’s why I plan on staying if I don’t go broke modding this truck.
    TheBeast likes this.
  30. Feb 9, 2019 at 1:30 PM
    #210
    Casper421
    In the woods
    06 DC
    I will be stealing this idea! How high would you say the rack starts off the bed rails? 3”?
