Spyder headlight problem
Discussion in 'Lighting' started by Cgonz9584, Jan 25, 2019.
  1. Jan 25, 2019 at 9:31 PM
    Cgonz9584
    Cgonz9584 [OP] New Member
    Carlos
    2010 Tundra DC RW
    2C99544B-BFDF-48B3-8CAC-E2C8C333DF88.jpg 8E7322EE-56E4-4EC8-82A7-13CEC41FB036.jpg I installed the spyder headlight on my 2010 tundra and it seems to work but it only came with 3 connectors. The original harness has 5 connectors to the original headlight. The led strip isnt turning on because i dont have anything to connect that wire to. (See pic)
    Also the light seems very weak, what hid kid can i buy to make the lights bright bright?
    All help will be appreciated.
    Thanks.
  2. Jan 26, 2019 at 3:47 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Ok so you have your high beam,low beam,running-blinker and side marker.the small plug you pictured goes to the original side marker light and if it’s dim flip the plug around and the last plug is likely your headlight leveling motor plug which is no longer used so put some dielectric grease in it and tape it up!
    Black Wolf likes this.
  3. Jan 27, 2019 at 11:50 AM
    Cgonz9584
    Carlos
    2010 Tundra DC RW
    Hopefully these pics help you guys help me.
  4. Jan 27, 2019 at 12:00 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Triangle looking plug is for leveling motors. Of your spyders don’t have motors then it will remain loose
  5. Jan 27, 2019 at 12:07 PM
    Cgonz9584
    Carlos
    2010 Tundra DC RW
    And the other plug from the cars harness ?
    Or the wire from the spyder light
    Do i just splice them together?
    Rica25 likes this.
  6. Jan 27, 2019 at 12:19 PM
    Rica25
    Ricardo
    Tulare
    Have to run to daytime running lights
  7. Jan 27, 2019 at 2:00 PM
    TXMiamiFan
    Jose
    Do you have a ballast? Or these HIDs?
  8. Jan 27, 2019 at 3:16 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @Cgonz9584, haven't dealt with Spyder headlights, but if you want to independently hook your led bar up, go with a fuse tap. No splicing just wire them via fuse tap into your ignition fuse. You will have to add another fuse with it.
  9. Jan 28, 2019 at 3:24 AM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Like I said Carlos,I have these exact lights on my truck and you definitely don’t need to splice or add fuse taps.tape the leveling motor plug off and plug in your high/low beams and your running/blinker light and all that is left is to pull the bulb out of the socket of the side marker and plug in the spyder u barplug ,if it’s dim unplug it and flip it over!
    Rica25 and parker44 like this.
  10. Jan 28, 2019 at 6:15 AM
    Rica25
    Ricardo
    Tulare
    Led strip does need to wired up
  11. Jan 28, 2019 at 6:23 AM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Rica25 likes this.
  12. Jan 28, 2019 at 6:28 AM
    War Machine
    War Machine SSEM # 5 3MW
    I had Spyders on my 2011 for a while, but they looked different. These are the ones I had:
    Spyder Auto 5012029 LED Halo Projector Headlights Black/Clear https://www.amazon.com/dp/B01AAX14NI/ref=cm_sw_r_cp_tai_QeXtCbQ6YDP38
    I don’t remember what had to be done, but the led bar did require a new wire to be run. A friend of mine did it for me, but I don’t remember what it was he did. I eventually removed them, as they just plain stopped working after a couple of years.
    Rica25 likes this.
  13. Jan 28, 2019 at 6:33 AM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    The ones op has are the newer version 2 and are plug and play,no extra splicing required.
