3rd gear
Discussion in '2.5 Gen Tundras (2014-2021)' started by arkhomer, Jan 23, 2019.
  1. Jan 23, 2019 at 3:03 PM
    arkhomer
    arkhomer [OP] New Member
    Tyler
    2024 Limited
    At approximately 30-35 mph if I let off the accelerator 3rd gear gears down way more than seems reasonable. I'm no mechanic but it just seems off. Is this normal? It's especially noticeable down hill.
  2. Jan 23, 2019 at 4:34 PM
    arkhomer
    Tyler
    2024 Limited
    Also noticed that with manual over ride regardless what gear you are in when you switch to manual it starts out at 4th gear. Seems like it would show what gear you are currently in?
    Adriver71x likes this.
  3. Jan 24, 2019 at 9:59 AM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Normal. Read manual
  4. Jan 25, 2019 at 4:30 AM
    arkhomer
    Tyler
    2024 Limited
    Thanks. Never thought that would be explained in the manual. I even felt a real harsh down shift when applying heavy pressure to the brake yesterday to stop at a red light. Right before I came to a stop. Guess it's something I'll just have to get used to.
  5. Jan 25, 2019 at 8:06 PM
    netranger6
    Jeremy
    Not really a manual. When you put it in that mode it defaults to 4th. You shift up to 5 or 6. Or down. And the trans will stay in that range. Example. Put in 6th and it wall use all gears. Put in 3rd will use 1st 2nd and 3rd.
