Door Sound Deadening Placement Question
Discussion in 'Audio & Video' started by effektz, Jan 23, 2019.
  1. Jan 23, 2019 at 11:57 AM
    effektz
    effektz [OP] New Member
    Fort Worth, TX
    2017 Tundra CM TSS Offroad
    Hi all! Longtime reader, first time poster. Had a question I could not find a direct answer for. I ordered Dynamat Xtreme to reduce road noise in my truck as it’s very loud in the cabin on my long highway commute everyday. I am planning to do the whole truck eventually but am going to start with the doors.
    During all my research on it, the only thing is not clear is are you supposed to add Dynamat to both the inner door skin as well as the area where the panel goes? Is there any benefit of doing both? Appreciate any help in advance!
  2. Jan 23, 2019 at 12:01 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    You definitely want to do your outer door skin, doing the inner door skin also helps, especially around the speaker. Really any undamped sheet metal will benefit from some dynamat. Just keep in mind, when you go to do your doors, carefully peel back the moisture barrier plastic and keep it intact. Stick it back in place when you are done. It serves to keep moisture out of the interior door panel and the cab.
  3. Jan 23, 2019 at 12:01 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Go big or go home. Do both inner and outer skin.
    Toyotoholic likes this.
  4. Jan 23, 2019 at 12:08 PM
    effektz
    Fort Worth, TX
    If I’m doing Dynamat over the entire door panel, where would the plastic go? Over the Dynamat? I’ve watched the install videos from Taco tunes and didn’t see them put the plastic back on? Maybe I missed that part, I’ll look again
  5. Jan 23, 2019 at 12:09 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    If you cover the entire hole that was covered by the moisture barrier, no - you don't have to put it back in.
    anthonygan and fortner28 like this.
  6. Jan 23, 2019 at 12:09 PM
    fortner28
    fortner28 New Member
    2017 SR5 Crew Cab
    Tacotunes recurve, Alpine PDX9, Hertz audio speakers
    you don't need to put Dynamat on the door skin. Place it on the metal. There is a plastic sheet tacked to the metal. I recommend taking the plastic off and placing the Dynamat in that same area. If you don't have enough material for that I would recommend covering places where the metal is a bit thinner and whatever voids you can. There are a lot of products out there that are a bit cheaper than Dynamat and works just as well.
  7. Jan 23, 2019 at 12:10 PM
    effektz
    Fort Worth, TX
    Are there areas in the inner skin that you don’t want to do? Mainly will the Dynamat block the window from coming down?
  8. Jan 23, 2019 at 12:13 PM
    effektz
    Fort Worth, TX
    Yeah definitely covering the entire whole like in the taco tunes video. I looked at other brands as well but Dynamat was only like 10-15 bucks more so I just went with that
  9. Jan 23, 2019 at 12:35 PM
    Danimal86
    Daniel
    Sacramento, CA
    I wouldn't do the outside of the inner skin, just inside of outter and inside of inner (what the speaker sits on) skin.....if that makes sense.
  10. Jan 23, 2019 at 12:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Dynamat alone will do very little for road noise. It's more for vibrations and rattles. To block road noise you need foam and something with a lot of mass, like lead sheets of mass loaded vinyl.
    Newm likes this.
  11. Jan 23, 2019 at 12:46 PM
    effektz
    Fort Worth, TX
    I think I follow you. I’m just asking about the metal you can see through the opening where the plastic front the factory is. Basically the backside of the door metal
  12. Jan 23, 2019 at 2:46 PM
    Danimal86
    Daniel
    Sacramento, CA
    Waiiiiiit a sec. You have a dark colored truck and you are in TX......I would just do the inside of the inner door skin. I remember reading somewhere that in hot climates sound deadener could melt and make a mess.....
    You are safe on the inner skin, but I wouldn't mess with the outer one that could get really hot .
  13. Jan 23, 2019 at 2:53 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    In my experience, quality sound deadener like Dynamat won't have an issue with Texas heat. I used to have a black truck with Dynamat on all the doors (inner/outer skins) and never had it melt or make a mess.
  14. Jan 23, 2019 at 2:56 PM
    Danimal86
    Daniel
    Sacramento, CA
    That's good to hear!
  15. Jan 23, 2019 at 3:05 PM
    effektz
    Fort Worth, TX
    My truck isn’t black, it’s the dark charcoal color but I see what your saying. So why do people do the outer skin, is there a benefit?
  16. Jan 23, 2019 at 3:18 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    This is how you do it if you want it to actually work. A single, unbroken piece that bonds the entire door. (No gaps or breeches)
    Inside the door too, overlapping so it doesn't peel off in the heat of summer, (applied with 600° heat gun to ensure proper initial adhesion).
    Spray door panels with deadener too then stuff any area that is a void with foam to get rid of any possibility of a fucking rattle!
    Relax and enjoy peace and quiet.
    ...and when you close the door, it sounds like an iron vault door, with a super deep thud as it shuts, not a tin can ready to cry.
    I use Cascade professional sound control products.
    In the car application it is called V-BLOK.
    http://www.cascadeaudio.com/
  17. Jan 23, 2019 at 3:23 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    The back wave of the speaker rings on the outer door metal. This causes terrible, and horrific anomalies in sound quality. The quieter every surface is, the better the sound quality and the less amount of power (amp) is needed to get good reproduction.
    Smoofers likes this.
  18. Jan 23, 2019 at 4:23 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    This. And it actually does cut down on road noise too.
    Toyotoholic[QUOTED] likes this.
  19. Jan 25, 2019 at 9:00 PM
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    I’m sure I’m not the only one to think dynamat is overpriced. So I researched and found this video of a product sold at Lowe’s. The guy who made the video also posted comments of how it’s holding up 4yrs later. I’m gonna go get some and install it. 50sqft of dynamat he mentioned is $220 where this product available locally is $60 for over 50sqft
    https://youtu.be/ZaE7RfkN1Eo
  20. Jan 25, 2019 at 9:22 PM
    Pudge
    CT
    Hate to break some bad news but that stuff is not the same as dynamat, it would probably be ok to cut down some vibrations and rattles but it doesnt have the same mass or other properties as dynamat. I would be worried about melting and smells from it. Theres another product called frost king duct insulation that people say is the same, it's not. Its light weight foam and foil, I got some and used it in a few spots for the purpose of rattles, but it's not a true sound deadening material, you'd get the same effect by gluing some skinny yoga mat material to the metal. Dynamat and other CLD tiles are very heavy and specifically designed for audio purposes. Idk what materials make up that stuff you posted, but if you strictly wanna cut down on minor rattling that is not caused by the stereo, I would suggest the frost king foam stuff.
  21. Jan 25, 2019 at 11:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    There is text in the video that says that he purchased from Rona..."its funny i keep saying lowes, because i bought it from RONA, why the hell i was saying lowes is beyond me"
  22. Jan 26, 2019 at 3:58 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I did the outer and inner door skins as complete coverage as i could get. I put a piece of 1/2" dynafoam behind eack speaker as well. For the 4 doors i used over 50sf of dynamat
    Photo of part way thru the outer door skin
    Finished door, i kept the dynamat 1/2 to 1" inside the line of the door panel so the panel would install tight to the door skim still.
    Flyinryank and Toyotoholic like this.
  23. Mar 17, 2022 at 4:03 AM
    KDK143
    KDK143 New Member
    Kurt
    2004 Tundra SR5 Access Cab
    2" leveling kit, cherry bomb glass pack, JVC touchscreen with backup camera, Bull Bar Bumper 17" Limited wheels with 265/60/17 Tires
    Great detail. Good job on the sound deadening. About to do this to my '04.
